Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
Glad the thread is helping Ted.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #132
Time to go to the junk yard, that's where we found whole pulley sets for custom cars.
Found a pulley at a local alternator/starter/generator builder. We'll see if it does the job. Still need to investigate the non-firing.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #134
I think you need to get that tune up kit on it as soon as you get it. Does your battery seem to be holding a charge? BTW GM parts on Fords never do work right. That is one reason I am against a 12v conversion.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #135
I haven't measured it, but the pulley on my MF-135 tractor's generator appears to be about 4" in diameter.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #136
alt pullies are remove in seconds with a blip of an impact gun.
I'm a day late after working a 12hr shift yesterday.. but for anyone interested.. a napa 213-4011B is a generic 3 wire delco 10si alternator. common clock like I might use on a tractor.. though easy to change...
if your brackets and geometry on the alt mount on a front mount make the belt rub.. install a idler puller at the lower bracket using along bolt and an off the shelf bearing'd pulley..e tc.
Parts arrived. I am going to try and do some trouble shooting before I just start ripping parts off. E.g. why it won't ignite and I'll swap the pulley, too.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #138
I think it is pretty safe to say you need a cap and plug wires.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #139
When troubleshooting ignition problems, the coil and condenser are usually the first things I check, with the latter being my first suspect. Assuming that the points look alright and that there are no other obvious problems visible.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #140
I would go ahead and replace everything that came in.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2006 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A52707)
2006 CATERPILLAR...
UNUSED SDLANCH 72" QUICK ATTACH BUCKET (A57193)
UNUSED SDLANCH 72"...
2012 Toro Workman HDX-D Diesel Utility Cart (A55851)
2012 Toro Workman...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
