disc vs spring tooth harrow on plowed land
   / disc vs spring tooth harrow on plowed land #12
I plow first with my Ford 101 - then use my JD 681 Roto-Tiller. When I am done we take a cultipacter next. Just a great job.
David Pidgeon
New Haven, Vermont
   / disc vs spring tooth harrow on plowed land #13
Rototillers work the soil excessively, causing it to break down into smaller pieces. Through wet dry cycles rototilled soil will compact much faster and harder than plowed and harrowed soil. The result is the need to work the soil more starting the process over. This is OK for a garden spot, because you rototill twice a year anyway. It also disrupts the microb's and bacteria in the soil. Plowing and harrowing works the soil less and is not as harsh, although no till is the best option for the soil. There is a lot of good info out there on the subject, I am by no means an expert.
   / disc vs spring tooth harrow on plowed land #14
It also makes soil wetter soil as overworked soil will not tolerate as much rain . Ocasional use realy is'nt going to make a difference though .
   / disc vs spring tooth harrow on plowed land #15
We try to work as little as possible in spring to avoid compacted wheel tracks and bringing up nasty lumps of clay . Chisel plough 4-6 inches deep twice in the fall in two directions then once over in spring with a tine harrow to warm and dry the soil whilst incorporating fertilizer ahead of the planter .
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
VINTAGE JOHNSON OUTBOARD MOTOR (A58374)
VINTAGE JOHNSON...
2017 Freightliner M2 106 24ft Box Truck (A56858)
2017 Freightliner...
JOHN DEERE LOADER BRACKETS FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE LOADER...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
