After 45 years, the carb started leaking on my MF 150 so I thought I'd try to rebuild it myself. This is my first carb rebuild and I'm probably in over my head, but how else does one learn.
I removed the carb and took it apart. It was pretty grungy, so I got one of the gallon cans of carb cleaner from Napa. It is the consistency of paint, I put the carb in the basket and soaked it for an hour (instructions only said 20 min). I pulled it out, rinsed it off and began trying to remove the seat. However, I can't get the seat to turn. When it didn't turn easily, I quit before I completely boogered the brass up. So I have two questions.
1. How are you supposed to remove the seat? Is there some special tool I need or a huge screwdriver? (pic attached for reference).
2. The float does not have a hole in it, but the sides appear to be caved in (pic attached for reference). I'd like opinions on whether I should replace the float as well.
Not sure if it matters, but the carb is a Marvel Schebler TSX 882.[/QUOTE
A huge screwdriver would have been the best place to start but at this point, I would suggest clamping the casting down to a secure object and take a flat pin punch and place it in the screwdriver slot and gently tap on the punch in the direction to loosen the seat. The only thing the seat seals on is a gasget so it should break free fairly easily. The key to remove these kinds of things is to have the piece secured so you can press down with the screwdriver and gently turn it. sometimes if you have a square shanked screwdriver rather than round you can press down on the screwdriver while gently turning the screwdriver with a wrench. After looking at the picture again you could remove the butterfly and throttle shaft and bolt the casting down through the throttle bore. If you could be very carefull and protect the casting with thin metal you might also take a hacksaw or thin file and square up the slots to have a more square screwdriver slot. Be very carefull not to file the casting face. This would be the most risky fix but if done slowly and carefully it may be successful.
