need new greese gun any ideals
   / need new greese gun any ideals #1
sam5570
south west virginia
new holland tn70
well my air greese gun blew up this morning so i got to have a new one. just wondred if there is any new guns that work as good or better than the air gun i have, i got it from napa about 5 years ago but would like a little better design than what mine is. the diaphram busted in mine so it's toast.
   / need new greese gun any ideals #2
I can't do a comparison to your Napa gun, but I just purchased a Lincoln 1162 Air Operated Grease Gun : Amazon.com : Automotive and so far, so good! I also bought the Lincoln Lubrication G310 Heavy Duty Grease Coupler : Amazon.com : Automotive
Bill thank's the linclon 1162 looks like a good gun, looks much better built with the springs on the hose.
   / need new greese gun any ideals #4
Have the same lincoln gun . Had it for a couple of years now . Has worked flawlessly . I do though , pull back the rod and lock it back so there is no pressure when not in use . Have done that with all my guns , manual or air , seems to save the plunger instead of mashing it out over time . Brother has the Lincoln battery operated also , But don't think he has had a chance to ever use it .
Fred H.
   / need new greese gun any ideals #5
Get a pistol grip grease gun with a rubber hose extension and buy the most expensive one you can.
   / need new greese gun any ideals #6
sixdogs, I bought a used pistol grip at a flea mkt years ago. It is either a Lincoln or Alemite. Never had any problem with it and I like it much more than a lever job.
   / need new greese gun any ideals #7
I got my pneumatic from Atwoods for $29 and it works like it should. Had it a couple of years and no problems pumping, it does get air locked sometimes when I change the cartridge but all grease guns do that.
   / need new greese gun any ideals #8
Yes--they are way better than the lever type in my view. With the pistol grip and a rubber hose I can grease anything out there. I also have a lever type I save for times when I need super-pressure but I haven't used it in several years. Quality is important as well with the $40 one I bought many years ago still working perfectly while several of the $12 ones have fallen by the wayside.
   / need new greese gun any ideals #9
I find that I need three hands with the lever type. Two to pump the gun and one to help keep the tip on the zerk fitting. I was going to buy a pistol grip but now I'm thinking of getting a batter powered one instead.
   / need new greese gun any ideals #10
Some people say the battery ones are underpowered and don't work as well as they should. There seem to be a lot of battery powered units for sale at farm auctions.
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
John Dozer JD650 (A51691)
John Dozer JD650...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
