need new greese gun any ideals
   / need new greese gun any ideals #1
sam5570
south west virginia
new holland tn70
well my air greese gun blew up this morning so i got to have a new one. just wondred if there is any new guns that work as good or better than the air gun i have, i got it from napa about 5 years ago but would like a little better design than what mine is. the diaphram busted in mine so it's toast.
   / need new greese gun any ideals #2
I can't do a comparison to your Napa gun, but I just purchased a Lincoln 1162 Air Operated Grease Gun : Amazon.com : Automotive and so far, so good! I also bought the Lincoln Lubrication G310 Heavy Duty Grease Coupler : Amazon.com : Automotive
Bill thank's the linclon 1162 looks like a good gun, looks much better built with the springs on the hose.
   / need new greese gun any ideals #4
Have the same lincoln gun . Had it for a couple of years now . Has worked flawlessly . I do though , pull back the rod and lock it back so there is no pressure when not in use . Have done that with all my guns , manual or air , seems to save the plunger instead of mashing it out over time . Brother has the Lincoln battery operated also , But don't think he has had a chance to ever use it .
Fred H.
   / need new greese gun any ideals #5
Get a pistol grip grease gun with a rubber hose extension and buy the most expensive one you can.
   / need new greese gun any ideals #6
sixdogs, I bought a used pistol grip at a flea mkt years ago. It is either a Lincoln or Alemite. Never had any problem with it and I like it much more than a lever job.
   / need new greese gun any ideals #7
I got my pneumatic from Atwoods for $29 and it works like it should. Had it a couple of years and no problems pumping, it does get air locked sometimes when I change the cartridge but all grease guns do that.
   / need new greese gun any ideals #8
Yes--they are way better than the lever type in my view. With the pistol grip and a rubber hose I can grease anything out there. I also have a lever type I save for times when I need super-pressure but I haven't used it in several years. Quality is important as well with the $40 one I bought many years ago still working perfectly while several of the $12 ones have fallen by the wayside.
   / need new greese gun any ideals #9
I find that I need three hands with the lever type. Two to pump the gun and one to help keep the tip on the zerk fitting. I was going to buy a pistol grip but now I'm thinking of getting a batter powered one instead.
   / need new greese gun any ideals #10
Some people say the battery ones are underpowered and don't work as well as they should. There seem to be a lot of battery powered units for sale at farm auctions.
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2018 Infiniti QX60 AWD SUV (A51694)
2018 Infiniti QX60...
