How to use front mount pump hydraulics for rear remotes?
   / How to use front mount pump hydraulics for rear remotes? #11
If his loader is like Dad's was (and I think it is), the tank is in the right loader tower (the one that the valve is mounted to). The tank goes from the back axle to the top of the loader tower and IIRC, the "tank" port on the valve goes directly inside the tank, down to the filter on the side of the tower (with a pipe inside the tank) and dumps back into the tank, so no external tank line to tee into. Hence my suggestion of welding a new fitting onto the tank/loader tower.
Aaron Z
So the valve dumps directly into the loader upright? There is not even a fitting that goes into the upright? I had an old 580 Case that had the reservoir and loader controls similar to what this is, but I faintly remember some short lines being there. But this I do not know for sure and it would be fairly easy to get a return fitting into the tank.:thumbsup:
   / How to use front mount pump hydraulics for rear remotes? #12
He will have to confirm how his is plumbed, but on Dads, there were 5 lines on the outside of the valve, 1 high pressure in and 4 out for the loader. Then there was one suction line on bottom (front?) of the tank which went to the suction side of the pump.
IIRC, there was a breather/dipstick that went into a NPT fitting in the top, but if you wanted to tun your tank line into there, you would need some way to make sure it sent down and not up/out through the breather.
Aaron Z
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
Case 2090 Cab Tractor with Loader (A55218)
Case 2090 Cab...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
