How to use front mount pump hydraulics for rear remotes?
   / How to use front mount pump hydraulics for rear remotes? #11
If his loader is like Dad's was (and I think it is), the tank is in the right loader tower (the one that the valve is mounted to). The tank goes from the back axle to the top of the loader tower and IIRC, the "tank" port on the valve goes directly inside the tank, down to the filter on the side of the tower (with a pipe inside the tank) and dumps back into the tank, so no external tank line to tee into. Hence my suggestion of welding a new fitting onto the tank/loader tower.
Aaron Z
So the valve dumps directly into the loader upright? There is not even a fitting that goes into the upright? I had an old 580 Case that had the reservoir and loader controls similar to what this is, but I faintly remember some short lines being there. But this I do not know for sure and it would be fairly easy to get a return fitting into the tank.:thumbsup:
   / How to use front mount pump hydraulics for rear remotes? #12
He will have to confirm how his is plumbed, but on Dads, there were 5 lines on the outside of the valve, 1 high pressure in and 4 out for the loader. Then there was one suction line on bottom (front?) of the tank which went to the suction side of the pump.
IIRC, there was a breather/dipstick that went into a NPT fitting in the top, but if you wanted to tun your tank line into there, you would need some way to make sure it sent down and not up/out through the breather.
Aaron Z
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
