NHmitch
I think that I may have a source for the splines, I'll let you know. From the looks of your G174 and the 3 cylinder engine, the exposed front PTO, and the decals, it looks like you have one of the "newer" G174's. Probably a late 80's, to around 1991.
I would also try contacting this seller on eBay. He is parting out a G174, and I have bought a few parts from the tractor. I believe that he may still have the transmission, and gears. Just contact him under the "contact seller" tab. Bolens Iseki G174 TX1500 Tractor Mitsubishi 17hp Diesel Engine Oil Pan | eBay
Your tractor is a cat 1, and you should be able to use most cat 1 implements keeping in mind that you have around an 800-900lb lifting capacity, and your three speed 17hp PTO. Once you get it running again, you may want to add some suitcase weights to the front depending on what you are going to use the tractor for. I also have a good source for a certified ROPS that is made for your G174.
