What loader bucket size for john deere 3520 with turf tires?
   / What loader bucket size for john deere 3520 with turf tires?
I use a 60" bucket with my 3520 and agri tyres. I find it already very cumbersome around trees and buildings and when full it is very heavy for the 300CX and the front axle. I wouldn't try anything bigger.
Thanks for the pictures! I'm sold on the 60". No turning back. Just not too many cons for the 60 with my situation. Hopefully this thread helps someone else out
   / What loader bucket size for john deere 3520 with turf tires? #22
Bigger is always better with snow, of course. If you're only planning (or would prefer) to buy just 1 bucket - get the 72 inch.
AKfish
That's what I used to think, until I bought a 84" Horst Materials Handling bucket for snow. The bucket is just too heavy to be a comfortable tool. Steering can be difficult with the bucket flat on the ground and in "float." For light snow the wider footprint and capacity are good, but if the snow is heavy, lifting a full bucket can be a challenge. If the bucket gets loaded off center it is real easy to be on three wheels, even with a BH for ballast. This season, I just used the HD 60" bucket on the front and 60" blower on back and found that to be a much better compromise. I have not tried a 72" bucket so cannot comment, except to say I suspect a full bucket of heavy material might be a stretch for the 3x20 series to lift.
   / What loader bucket size for john deere 3520 with turf tires? #23
I've got a 3320 with a 300cx loader and a 60" bucket. I added a tooth bar. I have rim guard in my rear tires and keep a box blade loaded with 10 suitcase weights on the back when using the loader. Still.....the rear can feel light at times....and I am going to rig for still more rear weight. The cx is one powerful loader for the tractor size.
I like the digging ability of the 60" bucket and tooth bar......and would not like a bigger one for my purposes. I can pick up a bucket full of anything....and have adequate ballast. But when I put my grapple on.....some of the trees I pick up can get a bit dicey. Lotsa leverage on a long tree cross-wise in the jaws.
   / What loader bucket size for john deere 3520 with turf tires? #24
I've got a 84" WorkPro bucket, too. (I didn't suggest that as an option...) It is a lot of steel hangin' on the end of the loader and I don't think I'd even consider hooking it up without chains on the front tires! :eek: I'd be afraid of skittering to and fro and end up stuck in the ditch or jammed into the side of the barn!
72" was more than my Model 80 FEL could lift (~1,200lbs) if the material was wet or fine (sand). So, I never attempted to routinely heap the bucket with that material. Snow, even wet snow - bring it on - as much as I could load into it.
Everything is a compromise. Nothing is perfect. Find something that fits most situations and go with it!
AKfish
   / What loader bucket size for john deere 3520 with turf tires? #25
Nice place you got there , soulasphil .
   / What loader bucket size for john deere 3520 with turf tires? #26
After I saw pictures of your bucket - that's when I decided I'd get a high volume materials bucket for snow. I bought the JD WorkPro materials bucket with SS quick attach mount. With chains on the front tires of my 110 or on my 5075M it moves mountains of snow!
This much I know... I can move and pile in less time, with less fuel than previously and that's exactly what I was hoping to achieve! :thumbsup:
AKfish
   / What loader bucket size for john deere 3520 with turf tires? #27
Thanks, that's southern Brittany. The water you might be able to see in the background of some of the pictures is part of the Atlantic Ocean.
   / What loader bucket size for john deere 3520 with turf tires? #28
For what you want, I would go with 60" to start. With that digging you will want a smaller bucket! Also you will not be using the replaceable edge with most tooth bars, just a heads up.
I have a 300cx, with a 60" HD bucket and 60" tooth bar. I also picked up a 72" bucket down the road for snow, I never use it.
does the cutting edge have to come off for it to fit? wont be a problem because of have air tools.
   / What loader bucket size for john deere 3520 with turf tires? #30
Yep... gotta remove the cutting edge. The toothbar won't fit over the top of the bucket edge with the cutting edge on there.
AKfish
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
206707 (A58375)
206707 (A58375)
Buffalo Model #3 Horizontal Angle Iron Roll (A59213)
Buffalo Model #3...
1779 (A58375)
1779 (A58375)
2006 Mac Truck CXN613 (A56436)
2006 Mac Truck...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
