3pt chipper will not lay flat
   / 3pt chipper will not lay flat #1
BUBBLEHEAD1
Alexandria, NJ
New Holland 2120
I am sorry for being such a nube, but I wanted to ask why my wallenstein 3pt chipper will not lay flat when I put it down from the up position. I tried adjusting top link, and that makes it a little better, but still has an angle to it. I will take a picture if need be and post it up over the weekend. Thank you.
   / 3pt chipper will not lay flat #2
set it on the ground and level it with top bar,, when you pick it up it will not be level because the bottom will push out and the top will pull in toward the tractor.. but when you set it back down then it will be level on the ground only.. Lou
   / 3pt chipper will not lay flat #3
Does the PTO shaft length shorten when you lower it?
   / 3pt chipper will not lay flat #4
Yes it does. The PTO shaft has to be cut to use on the tractor. Otherwise, you can jam
the two halves of the shaft and covers together. Everything Attachments on their website
has a good video on how to measure and cut the PTO shafts to fit..
Good luck.
Tom
   / 3pt chipper will not lay flat #6
There are, of course, different lengths of top-link bars, so you choose one with the range that you need.
   / 3pt chipper will not lay flat #7
I have a Wallenstein BX42. Mine does not go down all the way either. Note, however, while it is not in earth contact it can be adjusted LEVEL.
In my opinion Wallenstein's are designed this way so when mounted as rear ballast operators will not plow with the chipper when tractor is in reverse.
This Wallenstein peculiarity should be explained in the operator's manual but it is not mentioned.
First, lock tractor brakes "on" and lower FEL all the way to the ground, then put a 4" - 5" diameter ROUND branch under the support stand, in middle or slightly biased to the rear, and chip away. I have been carrying around my "favorite" 5" chunk of branch since the Wallenstein was new. Do not use a 4X4 timber or anything not ROUND.
If you add a longer top link the chipper will reach the ground but not be level. FOR SAFETY IT MUST BE LEVEL BEFORE YOU ENGAGE PTO.
This from my personal experience. Use info at your own risk.
If you create a new thread with Wallenstein in the title I believe you will receive confirming posts from other Wallenstein PTO chipper owners.
You guys are really good, I will use the round trick, because I already shortened the shaft just to be able to hook it up. It's not a giant problem, but in the videos and manual they stress that it has to be even. So thank you for all your responses.
   / 3pt chipper will not lay flat #9
I have a BX42S that I just purchased new in January. I could not get the links low enough to connect until I rotated the sway chain links to allow more play in my lower arms. I am over six feet tall. There are holes in the bottom of the skids on the chipper. One COULD place a 4X4 piece of lumber under each skid aligned one along the left skid, and one along the right skid. Add a few lag bolts and you have a chipper modified to meet a personal input chute height requirement. Oh, and I don't have to dismount my tractor to get my favorite little stick. Just FYI. It worked for me.
   / 3pt chipper will not lay flat #10
I have a BX42 on a JD 4120 and it doesn't reach the ground either. I have to set it on a pallet to remove it from the tractor. Why do you say to set it something round when chipping?
I was planning on welding on some permanent skid extensions (2 x 4 sq. tube) to solve the problem. I thought my tractor was just too big for th BX42 and didn't realize others had the same problem...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53473)
UNVERFERTH 330 -...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
Two Post Car Lift (A50120)
Two Post Car Lift...
KUBOTA SVL75-2 SKID STEER (A52705)
KUBOTA SVL75-2...
