Ok here is the cylinder I have found,, What do you think,,,, I'm going to look for a valve to run 2 of them next... ITR-2014 - Tie-Rod Cylinder - 2" X 14" by International Hydraulics
No.
Detent means that the lever will stay in a certain position, and fluid will continue to flow, or in a detent float position, the fluid is allowed to move in relation to the ground contour.
Detent could be a couple of balls in a groove holding the spool in position, pressure detent, or friction detent.
A log splitter valve has a detent in retract. You push the lever to retract, and the lever stays in detent until a certain pressure is reached, and then the lever returns to neutral.
Some valves could also have three position detent, where the lever can lock in three position.
The kit you show is for a spring center valve to convert it for a three position detent operation.
The three position detent will lock the lever in any of the three position.
If the pump is pumping, a detent lever will allow the fluid to flow through a work port to a motor. You would not want to detent a cyl, as when tthe cyl is fully extended or retracted, the relief would activate.
What is your intended use of a detent valve?
The below data is just some of the features that can be added to some valves.
Pressure Release Detent
1 Position Detent, Spool "out" Only,
Spring Center to Neutral
F**
2 Position Detent, Spool "in"
and "out", Spring Center
to Neutral
Spool "C" or "E" Only
G**
4 Position, Spring Center to
Neutral, Detent Spool In for
Float Position
