Massey Fergerson fuel line gromets/gaskets
   / Massey Fergerson fuel line gromets/gaskets #1
azrancher
Hereford, AZ
MF30, Case 580B, Case 550E Cat RD6
OK I got a MF30 industrial tractor, AD4-203 Perkins engine.
The fuel fittings have a 1/4" flared steel tube, with a rubber "gromet" next with the nut next, see rough pic for the gromet.
All the auto parts stores have come up with zero, where do I get these guys, I did use 2 A/C washers to replace the last ones when I did the fuel injector pump.
Rancher
   / Massey Fergerson fuel line gromets/gaskets #2
I just cut some 1/4" rubber fuel line real straight with a razor blade. Has worked good for me
   / Massey Fergerson fuel line gromets/gaskets #3
Have had good results as well doing this.
   / Massey Fergerson fuel line gromets/gaskets #4
These rubber olives are a standard Perkins engine component, available from any "Perins Engine" agent. ,!
What are they called, or do you have a part number?
Rancher
   / Massey Fergerson fuel line gromets/gaskets #6
They are called "rubber olives " !!!!! Dont have any part numbers , they were also used by IH on the 475 tractor.
Thanks that was the lead that I needed, they are also know as "fuel line sleeves" P/N 376525X1.
Rancher
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
Sullair 185 (A50123)
2010 CATERPILLAR 140M MOTOR GRADER (A51246)
2010 CATERPILLAR...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
