Massey Fergerson fuel line gromets/gaskets
   / Massey Fergerson fuel line gromets/gaskets #1
azrancher
Hereford, AZ
MF30, Case 580B, Case 550E Cat RD6
OK I got a MF30 industrial tractor, AD4-203 Perkins engine.
The fuel fittings have a 1/4" flared steel tube, with a rubber "gromet" next with the nut next, see rough pic for the gromet.
All the auto parts stores have come up with zero, where do I get these guys, I did use 2 A/C washers to replace the last ones when I did the fuel injector pump.
Rancher
   / Massey Fergerson fuel line gromets/gaskets #2
I just cut some 1/4" rubber fuel line real straight with a razor blade. Has worked good for me
   / Massey Fergerson fuel line gromets/gaskets #3
Have had good results as well doing this.
   / Massey Fergerson fuel line gromets/gaskets #4
These rubber olives are a standard Perkins engine component, available from any "Perins Engine" agent. ,!
What are they called, or do you have a part number?
Rancher
   / Massey Fergerson fuel line gromets/gaskets #6
They are called "rubber olives " !!!!! Dont have any part numbers , they were also used by IH on the 475 tractor.
Thanks that was the lead that I needed, they are also know as "fuel line sleeves" P/N 376525X1.
Rancher
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
2024 JOHN DEERE 8R 280 LOT IDENTIFIER 140 (A53084)
2024 JOHN DEERE 8R...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
2018 Bobcat E50 (A50123)
2018 Bobcat E50...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
