TODAYS SEAT TIME
   / TODAYS SEAT TIME #2,491
That is a awesome setup. I have heard the toolcat is great for snow removal.
Will move dirt also. Grading piles from a dump truck with a 6' boxblade on a Berlon Tilt-Tach.
   / TODAYS SEAT TIME #2,493
I always drool when I see a toolcat:drool::licking: A tilt-tach would be nice to have. Can you float the tilt-tach?
Yep, push the joystick all the way forward and the boom floats. Digging angle is the curl function, tilt is aux hydraulics slide switch on the joystick.
That is a 3 point to SSQA adapter on the boxblade
   / TODAYS SEAT TIME #2,494
   / TODAYS SEAT TIME #2,495
I meant could you float the tilt-tach, the side to side movement.
Nope, not without some modifications. There are times that would be handy. I will have to look at the possibility of making the tilt cylinder rod end pin removable.
I did add a flow restrictor to fine tune the tilt. Guess I need a float valve too.
   / TODAYS SEAT TIME #2,496
Yesterday's seat time included loading the truck for the dump.
The stumps where dug up using a 3.5t mini-ex. My little BX dropped them into the truck bed.
CHEERS!
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2016 Ranger 570 EFI (A52384)
2016 Ranger 570...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
