TODAYS SEAT TIME
   / TODAYS SEAT TIME #2,491
That is a awesome setup. I have heard the toolcat is great for snow removal.
Will move dirt also. Grading piles from a dump truck with a 6' boxblade on a Berlon Tilt-Tach.
   / TODAYS SEAT TIME #2,493
I always drool when I see a toolcat:drool::licking: A tilt-tach would be nice to have. Can you float the tilt-tach?
Yep, push the joystick all the way forward and the boom floats. Digging angle is the curl function, tilt is aux hydraulics slide switch on the joystick.
That is a 3 point to SSQA adapter on the boxblade
   / TODAYS SEAT TIME #2,494
   / TODAYS SEAT TIME #2,495
I meant could you float the tilt-tach, the side to side movement.
Nope, not without some modifications. There are times that would be handy. I will have to look at the possibility of making the tilt cylinder rod end pin removable.
I did add a flow restrictor to fine tune the tilt. Guess I need a float valve too.
   / TODAYS SEAT TIME #2,496
Yesterday's seat time included loading the truck for the dump.
The stumps where dug up using a 3.5t mini-ex. My little BX dropped them into the truck bed.
CHEERS!
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2430 (A51248)
2430 (A51248)
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
