No 4x4!!!
/ No 4x4!!! #1
spinetx
yuba city
mitsubishi mt210d
I hope this is not too much of a newbie question for my 2nd post. I just bought a used MT210 in decent shape. Hours meter says 400 although I found out it is not working very well. I noticed the front wheels are not pulling when its in 4x4. The front drive rotates when in 4x4 but the front wheels aren't pulling. They spin freely and there is no noise. When in put it in 2x4 I can freely spin the front driveshaft no noise and its smoothe. When in put it in 4x4 (tractor not running) I can't spin the driveshaft and it appears to want to spin the front tires. I have not been able to get it on jackstands yet. Butr I thought I would post here to see if anyone has a direction to point me to.
Also the rear locker seems to not be working. when I push the lever down it transfers power to the one or the there wheels but not both. Any ideas on this? Is there an adjustment for this?
/ No 4x4!!! #3
How have you established that the front tires do not pull? A quick way to check would be to see if the driveshaft spins when in 2 wheel drive. If not, there is something broken or missing in the front axle.
If the differential lock is activated, it forces the axles to spin at the same speed. It cannot send to one side or the other alternatively. Sometimes the engagement lever or fork can be bent by exerting too much pressure on the pedal. The only way to inspect it would be to open the transmission casting to access the differential.
Good luck! Take pictures of any repairs or actions you do, to help anybody else who has the same troubles.
/ No 4x4!!! #4
That is only half the equation, of course.
If the transfer case is blown, then the front differential and driveshaft will still turn when the tractor is moving.
Before you do much more, I'd look at all the linkages and make sure they are connected, and seem to operate when moving the levers. Also make sure you haven't lost some splines in the driveshafts, at least for the front.
Your tractor is small enough that it should be easy enough to jack up with just about anything.
/ No 4x4!!! #5
If you can spin the driveshaft when in 4x2 mode with the front tires on the ground, then it sounds like someone has removed parts. I would drain the front end oil and see if there is metal in it. Hopefully they drained the oil when they took out whatever. With the tractor in 4x4 and turned off and the front tires off the ground, if you can spin one side and the opposite side spins backwards, then the differential and spur gears on the Portals are intact and someone likely removed the Rind gear?
/ No 4x4!!! #6
Agreed; my observation was to help isolate what he has figured out so far, and how. Depending on how the MT210 is set up (And I don't have any clue) there is almost certainly either a sliding coupler that links a constantly spinning output shaft from the transmission to the front axle, or a sliding gear in a drop box that engages with another gear inside the transmission housing. Either way, the wheels should drive the front driveshaft when driving in 2wd. If not, the trouble is on the axle side or at the connection between the axle and the driveshaft. If the driveshaft does spin, then the difficulty is on the transmission output end. It could be a linkage, a CV/U-joint issue, stripped splines, a missing shear pin, or several other things.
/ No 4x4!!!
Thanks for the replies. I will do some more diagnostics this weekend. But let me clarify some things. When in 4wd and the tractor moving the front shaft spins but the front wheels don't pull. I know this because I put a load on the scraper box with the front end slightly de-weighted facing uphill. The rear wheels were at the base of the small incline. The rear driver's side wheel would spin. When in 2wd neither the front wheels nor the front shaft would spin (this is expected) however when put into 4wd the front shaft would now spin but the wheels would not.
Next, I tried engaging the rear locker. At first it did nothing the rear driver's side kept spinning but the passenger side did nothing. No noise,grinding, chattering, nothing. Out of curiosity I backed the tractor down to level, put trannies in neutral then pushed on the rear locker and engaged the trannies and instead of the driver's rear wheel engaging the passenger side engaged, but not both.
I hope this helps, and again thanks for the replies.
/ No 4x4!!! #8
The front drive shaft has a small solid pin, held in place by a wire clip that connects the shaft to the yoke on each end of the shaft . The first (and easiest) place to check is to take the metal cover off the front ( about 10-10mm bolts) and see if the pin broke or fell out.
On the locker, I don't know what to say other than it would probably involve taking the rear end apart and inspecting the mechanism. They can be damaged by being engaged while the wheels are spinning or repeatedly stomping on the pedal and eventually bending the pedal/ linkage so it doesn't engage.
/ No 4x4!!!
Thanks again for the replies. I got the tractor on jackstands last night. With the front off the ground, if I spin one front wheel the other wheel spins in the opposite direction. This happens in 4x4 and 4x2. When tractor is running in 4x4 the driveshaft still spins but the front wheels do not. The yokes are spinning too so I don't think there is a problem with the driveshaft connection to the yokes.
Now for the rear locker. I had the entire tractor suspended on jack stands and I could get the locker to engage but it kept wanting to disengage. I could feel the lever "bump" against my foot. Is there an adjustment for this?
/ No 4x4!!! #10
Sounds like the front differential has been neutered. There has to be some parts missing, possibly the pinion gear off the input shaft? When you spin one front wheel and the other turns opposite, that is normal. The locker might be a little loose, not sure. Is there a nut on the shaft where it pivots? Most are pretty tight and have to be freed up. Can you tell by a close inspection if this tractor has been disassembled? You could have one of the notorious vietnam rebuilds. Hope not.
/ No 4x4!!!
This is what I'm thinking. I will tear into it this weekend. There is a guard around the driveshaft at the front yoke that is missing half it's parts. So it looks like is has been messed with.
/ No 4x4!!! #12
Oliver is right on. It sounds like everything in the front drive system is working from the hubs to the diff. If the drive shaft is spinning the yoke, it should be turning the pinion gear shaft because the shaft is splined, not just pinned. Sounds like the issue has to be either a ring or pinion gear issue. I believe the pinion gear and shaft is one piece.
The lockslide has 2 dogs on it that engage the diff, the "bump" you are feeling is most likely those dogs attempting to engage. They or their corresponding slots are either too worn or something is loose or bent allowing a too short throw to enagment.
/ No 4x4!!!
Thanks,
I will post back here when I get it torn apart.
/ No 4x4!!!
I tore into the front end and the ring gear is not attached to the carrier. I don't yet know if the bolts have been sheered, if they backed out or both. I haven't split the case yet but the oil does not have any chunks of metal in it from what I can tell. and I cannot feel any metal in the bottom of the case. The mystery is there does not seem to be a way to get to the bolts on on the carrier/ring gear unless the case is split. So either the bolts have all sheered off and were fished out or somebody split the case and put the carrier and ring gear back in without the ring gear being attached. I will update when I split the case. Thanks or all the help.
/ No 4x4!!! #15
Good luck, I hope it turns out that the bolts were not put back in on re-assembly. There is a thread in part/repairs on dumb things like that. Haven't posted mine yet.
/ No 4x4!!! #16
I had all my carrier bolts shear on my MT180D. (cost me a carrier and pinion) When I re assembled I wire locked + used lock tight on the carrier bolts.
I believe that what occurred is that vibration and torque slowly loosened and unscrewed the carrier bolts.
The factory uses tin strips that have tabs that when bent should prevent movement but I did not trust this.
I also substituted graded bolts for the factory parts.
In effect all the ring carrier bolts had sheared and the heads that fell off damaged the gear pair.
Reading your post suggests that perhaps I should open my differential and verify my status B4 I might need to (again) repeat my repair. Bolts are cheap, ring and pinion not.
(I do use my FEL like it was a skid stear.)
PM me if I can help U.
Good luck!
/ No 4x4!!!
Good luck!
OK, the ring gear bolts were sheared off. The Carrier and ring gear need to be replaced. I will definately be safety wiring all of the nuts when I put it back together.
My question now is: Where do I get parts for this? I am really new to the tractor world and I know we don't have a Mistubishi tractor supplier around where I live. Is there a good online source for parts.?
/ No 4x4!!!
Does anyone know of a "used part" supplier for mitsubishi tractors?
