135 leaking utf
   / 135 leaking utf #11
Bout 2 qts over
Keep your tranny hydro fluid level at FULL or just slight above it if your using hydro attachments. They put marks on those dipsticks for a reason. -kid
   / 135 leaking utf #12
are three point arms suppose to be up or down when checking fluid level? Lift cylinder hold a lot of fluid. That why when you change it you are suppose to lower the arms to drain as much oil out of the system.
   / 135 leaking utf #13
I suggest you direct that question to someone you feel knows the answer.
   / 135 leaking utf #14
I checked my owners manual and as you stated you are supposed to drain the fluid with both hydraulic control levers in the down position and fill with 8 gallons of m1129 or m1129a oil. The manual does not state whether you have the three point arms up or down when checking the fluid level. It just states that the fluid level must be between the arrows on the dipstick.
   / 135 leaking utf #15
Yes, down is the answer.
   / 135 leaking utf #16
in the end.. the lift cyl holds very, very little. up or down on the 3pt lift will amount to 'ounces; of oil displacement..
i'd personally check down to prevent any chance of overfill..e tc.
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
