135 leaking utf
   / 135 leaking utf #11
Bout 2 qts over
Keep your tranny hydro fluid level at FULL or just slight above it if your using hydro attachments. They put marks on those dipsticks for a reason. -kid
   / 135 leaking utf #12
are three point arms suppose to be up or down when checking fluid level? Lift cylinder hold a lot of fluid. That why when you change it you are suppose to lower the arms to drain as much oil out of the system.
   / 135 leaking utf #13
I suggest you direct that question to someone you feel knows the answer.
   / 135 leaking utf #14
I checked my owners manual and as you stated you are supposed to drain the fluid with both hydraulic control levers in the down position and fill with 8 gallons of m1129 or m1129a oil. The manual does not state whether you have the three point arms up or down when checking the fluid level. It just states that the fluid level must be between the arrows on the dipstick.
   / 135 leaking utf #15
Yes, down is the answer.
   / 135 leaking utf #16
in the end.. the lift cyl holds very, very little. up or down on the 3pt lift will amount to 'ounces; of oil displacement..
i'd personally check down to prevent any chance of overfill..e tc.
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
TANK MANIFOLD (A58214)
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
Informational Lot - Shipping (A56436)
Informational Lot...
