12 volt water pump
   / 12 volt water pump #1
Zig
Bennington, Kansas
John Deere 3038e
I have a small trailer with a 250 gallon water tank on it that I pull around with my 3038 JD. I currently have a fimco 2.1 G.P.M. pump on it to help me water my small seedlings around the farm. Currently all my seedlings have tree tubes on them with a gallon milk jug attached at the bottom with a small hole in it to drip water on the trees. It works well enough, but it is slow to fill the jugs and I would like to speed up the process. (there are about 275 of these) I would like to get a pump that would take me closer to 4-5 gallons a minute and would like to have some recommendations on the type of pump that would be reliable and easy to hook up and use. I know that fimco makes a 3.8 gallon a minute rated pump but have not read great reviews on this. Any suggestions would be appreciated. The reason that I do run drip irrigation is because of no access to water in that area.
   / 12 volt water pump #2
I've been using a HF pump for a couple of years for this very purpose. Once after sitting all winter it wouldn't start and I took it apart and freed up the brushes. Ran fine all summer after that.
12v Marine Utility Water Pump
   / 12 volt water pump #3
I would go with one of the HF gas pumps. The one I bought a couple years ago for $200. does a great job of pumping water!
You can turn down the throttle to an idle and it still puts out a good stream.
If that's still too much you could rig a bypass to handle the volume.
   / 12 volt water pump #4
try a bilge pump for a boat ... small , cheap and a decent flow ( but no pressure )
   / 12 volt water pump #5
Any RV store will have a wide selection of 12V pumps in all styles, most of them are on demand pumps so it will have a pressure switch/regulator. You can go to an industrial supply store like Graingers and get heavy duty 12V constant pumps for things like carpet cleaning machines and sprayers. Expect to spend $150-250 for a decent quality pump.
   / 12 volt water pump #6
+1, bilge pumps have good flow rates, just adapt the outlet down to whatever hose size you're using.
   / 12 volt water pump #7
But no lift. 3 to 5 feet max.
Chris
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
2024 KRUZ Ravens Tri Axle Dump Trailer (A47384)
2024 KRUZ Ravens...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
