12 volt water pump
   / 12 volt water pump #1
Zig
Bennington, Kansas
John Deere 3038e
I have a small trailer with a 250 gallon water tank on it that I pull around with my 3038 JD. I currently have a fimco 2.1 G.P.M. pump on it to help me water my small seedlings around the farm. Currently all my seedlings have tree tubes on them with a gallon milk jug attached at the bottom with a small hole in it to drip water on the trees. It works well enough, but it is slow to fill the jugs and I would like to speed up the process. (there are about 275 of these) I would like to get a pump that would take me closer to 4-5 gallons a minute and would like to have some recommendations on the type of pump that would be reliable and easy to hook up and use. I know that fimco makes a 3.8 gallon a minute rated pump but have not read great reviews on this. Any suggestions would be appreciated. The reason that I do run drip irrigation is because of no access to water in that area.
   / 12 volt water pump #2
I've been using a HF pump for a couple of years for this very purpose. Once after sitting all winter it wouldn't start and I took it apart and freed up the brushes. Ran fine all summer after that.
12v Marine Utility Water Pump
   / 12 volt water pump #3
I would go with one of the HF gas pumps. The one I bought a couple years ago for $200. does a great job of pumping water!
You can turn down the throttle to an idle and it still puts out a good stream.
If that's still too much you could rig a bypass to handle the volume.
   / 12 volt water pump #4
try a bilge pump for a boat ... small , cheap and a decent flow ( but no pressure )
   / 12 volt water pump #5
Any RV store will have a wide selection of 12V pumps in all styles, most of them are on demand pumps so it will have a pressure switch/regulator. You can go to an industrial supply store like Graingers and get heavy duty 12V constant pumps for things like carpet cleaning machines and sprayers. Expect to spend $150-250 for a decent quality pump.
   / 12 volt water pump #6
+1, bilge pumps have good flow rates, just adapt the outlet down to whatever hose size you're using.
   / 12 volt water pump #7
But no lift. 3 to 5 feet max.
Chris
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
DHE 38-7 7 SHANK ALL PURPOSE PLOW (A51243)
DHE 38-7 7 SHANK...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
