twodogs
I like the M&P line. You may want to check out an apex trigger kit for your M&P. It does a fantastic job with the trigger, which helps to improve accuracy. If you are firm on your choice as a handgun for HD, I would stick with the M&P and look into the APEX kit.
That said, having recently taken an NRA course on HD, I would consider a few things: What is the construction of your home - brick or siding? Do you have neighbors close to you that might be endangered by stray rounds? Do you have other occupants in the house that might be affected by bullets passing through walls? I used to have a 12 gauge with 00 buck behind the door, but I have since switched to birdshot. At close range (most indoor situations), that will be more than adequate while limiting collateral damage.
Do what works for you. Good luck!
