Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #481
no need to mess with it in hard pouring rain in the middle of a lake. it woill only make you madder. :)
Thanks Soundguy. Wise advice.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #483
Maybe you need to add a small boat
and outboard motor to your farm.
After reading some other forum posts I think it is wise that I a) replace or clean the plugs and b) rebuild the carb. Just like you all have recommended.
May not be my only problem but may be a good long term thing to do. I will check the distributor first just because it is just sitting there. Should be able to get to it tomorrow night.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #485
Sounds like you are on the right track.
Must have been flooded. Started right up tonight before I pulled the distrib. Even drove it for a bit and used the carry all. Checking timing now.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #487
keep us posted.
Well, first things. The cork seals on the distrib were pretty wet so that may have been the cause for not starting (although I had spark?). The tarp was blowing around during all of the rain we got and it could have soaked everything.
On to the timing -- definitely out of wack per the manual. Doing the whole straight edge and pencil in the whole trick at 1/4" gap the points are closed -- manual says they need to be open at this point. Updating now.
Can someone explain how the plate on the left hand side adjusts timing? I just loosed the screw, moved the plate down, and it seemed like nothing happened.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #490
that screw is issentially moving the breakers a tad
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
John Deere 7130 (A53314)
John Deere 7130...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
