Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #481
no need to mess with it in hard pouring rain in the middle of a lake. it woill only make you madder. :)
Thanks Soundguy. Wise advice.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #483
Maybe you need to add a small boat
and outboard motor to your farm.
After reading some other forum posts I think it is wise that I a) replace or clean the plugs and b) rebuild the carb. Just like you all have recommended.
May not be my only problem but may be a good long term thing to do. I will check the distributor first just because it is just sitting there. Should be able to get to it tomorrow night.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #485
Sounds like you are on the right track.
Must have been flooded. Started right up tonight before I pulled the distrib. Even drove it for a bit and used the carry all. Checking timing now.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #487
keep us posted.
Well, first things. The cork seals on the distrib were pretty wet so that may have been the cause for not starting (although I had spark?). The tarp was blowing around during all of the rain we got and it could have soaked everything.
On to the timing -- definitely out of wack per the manual. Doing the whole straight edge and pencil in the whole trick at 1/4" gap the points are closed -- manual says they need to be open at this point. Updating now.
Can someone explain how the plate on the left hand side adjusts timing? I just loosed the screw, moved the plate down, and it seemed like nothing happened.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #490
that screw is issentially moving the breakers a tad
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A55853)
2009 Skeeter SL190...
John Deere 1025R (A53317)
John Deere 1025R...
