Irrigation economics and logistics
   / Irrigation economics and logistics
$150ish (with tax) will get you a 1" gas powered water pump such as 1" Clear Water Pump with 79cc OHV Gas Engine. Add a roll of black poly pipe and a suction strainer and you would be good to go.
Aaron Z
I think that might be the ticket! Thanks aczlan. Here's one that's a 2" that I found on Amazon. Amazon.com: DuroMax XP650WP 3-Inch Intake 7 HP OHV 4-Cycle 220-Gallon-Per-Minute Gas-Powered Portable Water Pump (CARB Compliant): Patio, Lawn & Garden
Looking to the future, would this be a handy thing to have? Should I step up to a better brand for longevity?
   / Irrigation economics and logistics #15
I like the idea, but the problem with that one is that when you hit 20' of head, your flow will be non-existent. See RUP160 | Wayne Pumps for the flow table on that pump.
I might go for something more like this one: Ironton Cast Iron Clear Water Pump - 720 GPH, 1/2 HP, 1in. - Amazon.com which is "rated" at 110' of lift.
Aaron Z
I was just noticing the same thing. There are charts on the Wayne website with flow given per feet of head. How did you find the Ironton pump? I can't figure out a good way to search amazon for pumps with more head. Is there a type of electric pump that produces more head? I also can't find the wattage requirement for this pump, which will be important for generator sizing.
   / Irrigation economics and logistics #17
With an electric pump you would need to know the starting draw to ensure your generator could start it.
   / Irrigation economics and logistics #19
Yeah I wouldn't think so.
Might want to think about building a pump system as close to what you think you would need if you build a house there. Actual irrigation pump, pump shed etc. Small pump like that wouldn't handle lawn irrigation etc.
   / Irrigation economics and logistics #20
Sorry 2LaneCruzer, I wasn't trying to be "smarmy". I've done the landscapping in 5 different houses with drip irrigation systems and I'm a huge fan. They're pretty cheap, user friendly, customizable, and best of all can be put on a timer. I just need to figure out how to get some water up in the air to feed it.
No offense taken; I can see you are a gentleman.
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
Case IH Farmall 75C (A52349)
Case IH Farmall...
Year: 2012 Make: Honda Model: Pilot Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2012 Make...
