MF135 REAR WHEEL REMOVAL
   / MF135 REAR WHEEL REMOVAL #11
Do you remove the exhaust to go under the olive trees? I'm thinking about a horizontal exhaust for mine to work in the woods.
I bought it from a guy who used it in his olive orchard and the tractor had the exhaust system arranged in the low configuration then. I use it in my hayfield so I modified the exhaust as shown in the photo.
   / MF135 REAR WHEEL REMOVAL #12
I use a long pry bar. Lay it on the floor at the center of the axle and roll the tire over it. Then just balance it with your left hand and pry with your right.
   / MF135 REAR WHEEL REMOVAL #13
Thanks for explaining.
   / MF135 REAR WHEEL REMOVAL #14
Has anyone got any tricks of the trade to remove the rear wheels of my MF135. The nuts have been loosened off, it's just a matter of manhandling the wheel and getting it back on
I use the Shop Crane to lift the wheel and move it, same thing I use to break the bead.
   / MF135 REAR WHEEL REMOVAL #16
That's a neat way to put your hydraulics to work.:thumbsup: Good thinking.
Thanks, I wish I'd taken a picture of the setup before I applied pressure, the solid steel bar was up on edge, next to the C clamps, against the bead. It still took a lot of effort on the jack handle! :)
Ford Dully Bed (A57453)
Ford Dully Bed...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
1995 Rinker Captiva 190 (A56436)
1995 Rinker...
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
8' Avalanche Snowbox (A55272)
8' Avalanche...
