I Already Took Off the Snowblower and Tire Chains
   / I Already Took Off the Snowblower and Tire Chains #51
The April snows up here in the tri-state area shattered records. More than 20" at Bismarck. It's getting a little old.
I have a DR Power Grader en route—and a great set of ruts to test it on.
Tom
   / I Already Took Off the Snowblower and Tire Chains #52
I have a DR Power Grader en routeé*�nd a great set of ruts to test it on.
Tom
Hello Tom,
do you have a piece of Steel or PVC pipe slit length ways covering the cutting edge to prevent diggging up the driveway?
I will be installing my pneumatic casters, work lights and slick sheet material
on my 44 inch JD/RAD snow caster this summer.
Dont worry about the snow until you see BNSF and UPRR running around with
those )(*&^%$%^&* excuses for rotary snow plows on their main
and secondary rail lines.
   / I Already Took Off the Snowblower and Tire Chains #53
Ha! I will follow that advice—and the PVC pipe sounds like a good idea, too.
Tom
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MILWAUKEE SAWZALL W/ CASE (A58374)
MILWAUKEE SAWZALL...
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
2016 GREAT DANE 53’ REEFER TRAILER (A58018)
2016 GREAT DANE...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
