I Already Took Off the Snowblower and Tire Chains
   / I Already Took Off the Snowblower and Tire Chains #51
The April snows up here in the tri-state area shattered records. More than 20" at Bismarck. It's getting a little old.
I have a DR Power Grader en route—and a great set of ruts to test it on.
Tom
   / I Already Took Off the Snowblower and Tire Chains #52
I have a DR Power Grader en routeé*�nd a great set of ruts to test it on.
Tom
Hello Tom,
do you have a piece of Steel or PVC pipe slit length ways covering the cutting edge to prevent diggging up the driveway?
I will be installing my pneumatic casters, work lights and slick sheet material
on my 44 inch JD/RAD snow caster this summer.
Dont worry about the snow until you see BNSF and UPRR running around with
those )(*&^%$%^&* excuses for rotary snow plows on their main
and secondary rail lines.
   / I Already Took Off the Snowblower and Tire Chains #53
Ha! I will follow that advice—and the PVC pipe sounds like a good idea, too.
Tom
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
Toro Mower NR (A56857)
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
110 GALLON FUEL TANK (A52708)
110 GALLON FUEL...
Deere 35P (A53317)
Deere 35P (A53317)
