Lifespan of Trailer Tires
   / Lifespan of Trailer Tires #61
Speed may have something to do with it, as does weight and proper inflation. And perhaps the manufacturers are not making ST tires as good as before, but I'd find that hard to believe since they've obviously improved other tires.
I bought a 32' fifth-wheel in the Fall of 1988. It had two 3500# axles, the mobile home type wheels, and bias ply load range C tires. Of course, we were a bit overloaded; living full time in it with generator, washer/dryer, etc. And I failed to weigh it initially, but after ruining a couple of tires enroute to Alaska in 1990, I found that we actually were running with 7,300# on the axles and 2500# on the pin, so technically we were only 300 pounds overweight, but of course some rough roads had an effect, too, broke 2 shock mounts, also. However, Goodyear had just come out with the first radial ST tires; the Marathons, so when we came south again, I planned to change some things. After considering heavier duty tires and springs and talking to the trailer manufacturer as well as Dexter Axle folks . . . well, we just replaced everything from the frame down; new custom built 5,200# axles with the 6000# tubes, bigger hubs and brakes, and D rated Marathon tires, and of course different wheels. That was done in Elkhart, IN. I'm not sure how many miles we put on it in the next year, but we went on to West Virginia, to Dallas, to the Texas Coast, back to Dallas, and the next April to Alaska, then in September back to Las Vegas where we traded the truck and trailer for a motorhome. So we'd driven in Texas heat and I know it was 5 below zero when we entered Alaska from Canada, so we'd traveled quite a few miles, in heat and in cold, usually driving the speed limit and never had a tire problem. Of course when I bought the Marathons, I bought 5 of them, but the spare was never taken off the spare rack.
So I only had good things to say about the Goodyear Marathons, but I was running considerably below their rated weight capacity AND that was more than 20 years ago, so I don't know how much has changed since then, but obviously a few things have changed.:laughing:
   / Lifespan of Trailer Tires #62
Do you find the same lifespan on trailer tires with a G rating and 14ply? I have two dully Gooseneck trailers with ST 235/80 R16 LRE tires and one bumper pull 10K dump trailer at 235/85 R16 LRG 14 ply but G rated, However, my biggest concern now is that I will have to replace all the tires on my gooseneck trailers as the tires are six years old? I also just converted my older Metavic log loader onto a new trailer (see below) and used 10ply tires and possibly should of gone to G rated ones? Given the two older GN trailers are six years old with the original tires would I get a longer lifespan from G rated trailer tires or is it just the nature of the beast? I will never use the trailers enough to wear out the tread but can't be without them for transporting my equipment. The trailers do sit outside all the time but when not being used are empty (no load). Thanks Log Trailer (2).jpg
   / Lifespan of Trailer Tires #63
Do you find the same lifespan on trailer tires with a G rating and 14ply. I have three two large Gooseneck trailers with ST 235/80 R16 LRE and then a smaller bumper pull 10K dump trailer at 235/85 R16 LRG 14 ply tire and I must admit that G rated tire has held up much better. However, my biggest concern now is that I will have to replace all the tires on my gooseneck trailers as the tires are close to six years old? I also just converted my log loader onto a new trailer (see below) and used 10ply tires and possibly should of gone to G rated ones? as the as two of the trailers are now six years old with the original tires. Do I get any more life from G rated trailer tires or is just the nature of the beast? The trailers do sit outside all the time but when not being used are empty (no load). Thanks<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=314198"/>
Time is usually the limiting factor but going with the heaviest load rating for your wheels and axles is always a good idea.
Chris
   / Lifespan of Trailer Tires #64
Do you find the same lifespan on trailer tires with a G rating and 14ply? I have two dully Gooseneck trailers with ST 235/80 R16 LRE tires and one bumper pull 10K dump trailer at 235/85 R16 LRG 14 ply but G rated, However, my biggest concern now is that I will have to replace all the tires on my gooseneck trailers as the tires are six years old? I also just converted my older Metavic log loader onto a new trailer (see below) and used 10ply tires and possibly should of gone to G rated ones? Given the two older GN trailers are six years old with the original tires would I get a longer lifespan from G rated trailer tires or is it just the nature of the beast? I will never use the trailers enough to wear out the tread but can't be without them for transporting my equipment. The trailers do sit outside all the time but when not being used are empty (no load). Thanks<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=314198"/>
With a trailer like yours, if you are doing short trips and don't mind a few road side break downs. I'm basing on the fact that your trailer has duals and double axle, lots of redundancy and likely used under capacity. I'd probably wait until the second tire failure than replace them all. Jmo.
   / Lifespan of Trailer Tires #65
There are much better products out there than Slime for your tires. I have been to a few tire shops that once they saw the slime oozing out, they filled the tire back up with air and sent me packing.
There are products that claim to help keep the tires cooler when running and to help preserve the life of the rubber as well as to help stop flats when accidentally running over nails or similar objects.
I run tubless slime in my tractor tires. At 22 PSI it does the job for the occasional nail.
   / Lifespan of Trailer Tires #67
I do not like the idea of replacing 16 tires that appear in great shape but I hate even more the thought of a blowout on the highway when your towing a trailer loaded to nearly 20K?. When I use the trailers I am seldom light on my trailer loads so like the orginator of this thread this will be expensive! If I never come close to wearing out the tires and it is just a matter of time then going to G-rated 14 ply tires would not really help me as far as the lifespan. I have so far had no problems with the 10 ply E rates tires. As far as my log trailer I wish I had put G-rated tires on them as they get abused and I am close to capacity at times. Anyway thanks for all the good advice.
   / Lifespan of Trailer Tires #68
Lost a trailer tire today 205/75/15 Douglas wally world special 4 tires for 100 bucks installed 8/82005 loaded the L5740 on the 16 ft trailer for a trip to the dealer for a loader valve issues. i got 5 miles from home never exceded 50 mph.poof..
Guess age and weight got another.....limped it home and went to wally world paid 75 out the door for a replacement didnt have the douglas got a good-for year. Got the job done. Think I will look for three more and just swap them out later.
Great info from everyone. I am thinking that since my tractor is under 2000lbs and that the trailer and tires are good for over 4000lbs that if I have to I can make the 48 mile trip to the dealer at 50 or less and will be fine even if I lose one along the way.
This is the trouble w owning trailers that do not get used much.
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55302)
UNVERFERTH 330 8...
2021 CHEVROLET SILVERADO 2500HD (A55745)
2021 CHEVROLET...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
30008 (A53424)
30008 (A53424)
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
