spreading mulch with a tractor
   / spreading mulch with a tractor #1
tractchores
Ma
Kubota b2920
I'm mid way through my annual mulch spreading on flower beds around the house. I have to spread around 8 or 9 yards once a year. My normal method is to scoop up a bucket load, drive and position the bucket and then throw it by hand on the beds. In areas where I can't or don't want to take a tractor I fill a wheel barrel with the FEL and use that.
My big question is - is there a better way to spread mulch with a tractor? Right now it takes a solid 5 -8 hours depending on how hard I work (usually am doing it myself). Is there a better way?
   / spreading mulch with a tractor #2
get rid of the flower beds? :)
Then I have to mow it! It'd be nice to let it just grow up and mow it a few times a year, but the wife won't accept that.
   / spreading mulch with a tractor #4
mowings easier than mulching in my book.
my last house I had landscaped beds around the perimeter of the house and around a tree inthe front yard.. and onthe sides.
insurance co on my next house advised against them due to moisture and wood debris near house / termites. I was happy too.
I just mow now. :)
   / spreading mulch with a tractor #5
You drive the tractor and "let" your wife spread the mulch.:thumbsup:
   / spreading mulch with a tractor #6
Get a pto manure spreader, fill with mulch, back up to the area to be spreading mulch and ingage pto... watch the mulch fly!
mark
   / spreading mulch with a tractor #8
Tratchores.
I use the FEL bucket and make small piles in beds and at the edge where I can reach with the FEL then use a rake to push around.
For those other areas deeper in beds maybe 30% I use a wheelbarrow I fill with mulch at the pile using the FEL.
Takes most of a day to do 15 yards.
   / spreading mulch with a tractor #9
Use a big flat shovel, I have an old shovel from my grams coal bin that holds a lot of mulch. I find its easier to throw the mulch into position then move it by hand/rake if needed.
   / spreading mulch with a tractor #10
I pile in the front of the beds with the FEL and then rake back....I put down 15 yards a year around my house....
   / spreading mulch with a tractor #11
I go and get a trailer full with my SUV, then hitch up the trailer to my tractor when I get home. I drive the trailer around from bed to bed, and pitchfork directly from the trailer into the beds. My beds are all about 4-5 feet wide (from the house foundation).
Thanks, some good ideas. I like the wife one the best, but so far no dice on that, she seems to go 'missing' when its time to mulch! I have done some of the dump a pile and rake it or use a pitch fork to spread it (which works decently). I even tried some areas where I back dragged the fel, which worked but used a huge amount of mulch. I wonder if they make one of those PTO mulch blower things....
   / spreading mulch with a tractor #13
Yep, they rent the mulch blowers Finn Bark BB302 Blower for rent
But I think you need someone filling it and someone spreading it.
My advice is to get a helper.
I used to "do it all" - mulching, edging 800' of beds, and about 3 years ago we found a fellow to assist, and it makes things bearable and manageable.
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
set of 4 tractor trailer tires Roadforce (A61306)
set of 4 tractor...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
