Want to make ball hitch attachment for the three point lift, Any made?
   / Want to make ball hitch attachment for the three point lift, Any made? #11
I build reciever style hitches from old take off hitches removed from a truck, most any car dealer has them out back. They remove them so the potential next buyer won't realize the truck was ever used for heavy towing. You cut the tubing to the correct width, add lower pin brackets, add tubing to attach the top link, simple build. I pick them up for 10.00 each, cheaper than buying just the reciever tube and building the rest from scratch.
   / Want to make ball hitch attachment for the three point lift, Any made? #12
Just found a hitch on clearance for 15 bucks gonna cut to width and add pins and an upright with a 2 5/16 ball for gn hitches
   / Want to make ball hitch attachment for the three point lift, Any made? #13
Here is one that I did as an early welding project. The welding could be a lot better, but it will give an idea of one approach. Note, the weight and pull is on a heavy duty drawbar, so it should hold. My welds are just keeping it upright.
Ken, you did a little nicer job than I did, but mine served my purposes.:D See post #9 in this thread: http://www.tractorbynet.com/forums/attachments/6912-draw-bar.html#post70750
   / Want to make ball hitch attachment for the three point lift, Any made? #14
If you use a receiver for the upright, you can do a lot more with it than just a gooseneck ball on top.
The carry box.
   / Want to make ball hitch attachment for the three point lift, Any made? #15
Here are a couple samples of my inventions......
If I can get multiple pictures to attach....
Good luck
   / Want to make ball hitch attachment for the three point lift, Any made? #16
I have 2 laying around. I am going to make a trailer mover with 1. IDK what I am going to do with the other.
   / Want to make ball hitch attachment for the three point lift, Any made? #17
Here's mine
Cost:
3-D rings $15
2-Chain hooks $10
1-receiver tube $12
1-Pintle hook $90 Optional
Orange rattle can paint $10
Lower and upper link pins $15
Scrap 3-1/2 x 3-1/2 tubing & flat bar $Free
So I have $62 in it less the pintle hook......and my time..........I enjoy fabricating so my time is my hobby.
   / Want to make ball hitch attachment for the three point lift, Any made? #18
^^^ Great idea with the chain hooks and D-rings.
   / Want to make ball hitch attachment for the three point lift, Any made? #19
Yeah .... I run the chain through the bottom of the D ring and then adjust the length using the chain hook.
That keeps the chain pulling as low as possible.
I ran out of leftover chain hooks and couldn't put one on top of the upright.
   / Want to make ball hitch attachment for the three point lift, Any made? #20
Here's a picture with the winch mounted.
the bottom tube of the winch has a D ring for connecting the cable to when using a snatch block.
71069 (A49346)
71069 (A49346)
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
