Front-End Loader Trailer mover for FEL
   / Trailer mover for FEL #1
corey9212
Red Deer County, AB
2015 John Deere 3046R
Hello I was wandering if anyone knows where I can get a trailer mover for my FEL (like the ones the trailer dealerships have) my tractor has a global carrier and I've searched all over the net with no luck. I would like one that has all the ball sizes plus be able to haul around a fifth wheel. Even if someone knows where I can get some plans to make my own would be sweet but buying one would be easier if possible.
Thank you.
Corey
   / Trailer mover for FEL #2
I googled loader bucket trailer hitch and came up with many hits. You could just add a Tripple Ball Trailer Hitch, HarborFreight has them.
   / Trailer mover for FEL #5
I built a simple one for my Kioti, but i have the ability to lift the weight. What is the lift capacity of your tractor. Mine is over 2,500 pounds if i remember right. My 5th wheel picks up real easy, but i do need counterweight on back.
I added a plate of 3/8" steel on top and bottom of my bucket and inserted a 1" shank 2-5/16 ball thru the resulting 1" thick steel. works great.
I made a removable 2" receiver for the smaller trailers. i had to make it extend so i could see it thru the cab without having to stand up and press face on the glass.
Its so much easier moving trailers with the FEL. you can push theme anywheres you want. I pot my 5th wheel 29'8 trailer in a 30' wide barn with absolute precision 0327111410.jpg0327111953.jpg0329111630.jpg0329111630a.jpg_MG_5063.jpg0403111220.jpg.
   / Trailer mover for FEL #6
What about for moving fifth wheels?
Looked all over on the net for what you are looking for. Looks like you may have to purchase a hitch and mod it to the bucket. I will tell you that I moved a large commercial sized wood chipper out of a low lying area on my property using my BX2660 and a chain hooked to the bucket; it was a bit scary. I wouldn’t want to do it again.
   / Trailer mover for FEL #7
Its so much easier moving trailers with the FEL. you can push theme anywheres you want. I pot my 5th wheel 29'8 trailer in a 30' wide barn with absolute precision.
Yours is a gooseneck trailer. A fifth wheel pin doesn't stick down as far, and uses a plate to latch on the pin.
I agree about pushing trailers, much better! :D
The pin weight is 2,250lbs and the loaders lift capacity is 4228lbs. I know all the rv dealerships here have an attachment in their quick attach that allows them to move any trailer type, I'm wishing I took a pic of one.
   / Trailer mover for FEL #10
They are most likely homemade. Just draw something up. Make sure you have an attachment spot for safety chains.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
John Deere 3025E (A53317)
John Deere 3025E...
