Lawn aerator/ plugger
   / Lawn aerator/ plugger #1
check 6
Gold Member
South Texas
BX 2680. Front bucket, grapple, pallet forks, box blade aireator 008-5 excavator ZD 1211 mower RTV 500
Looking for a aerator/ plugger to attach to my BX 25. Most of the ones I have found are 72" or larger. That size would not work on a normal lawn evan a large one constantly working around trees, scrubs etc. There has got to be a manufacture that makes one approximately 48" wide that attaches via the three point hitch. Anyone know of one?
   / Lawn aerator/ plugger #3
If I was going to buy a new one for a BX it would be this one. I like the looks of the design. It looks like it would have a lower center of gravity.
Xtreme Duty Lawn Aerator With Hollow Coring Tines
Here is my areator. I works really well. It does make the tractor more top heavy once you get it loaded down with blocks. A 48" is definitely as large as I would want to go on a BX.
Thanks, the xtreme duty unit looks like what I'm looking for, I will give them a call
   / Lawn aerator/ plugger #5
What brand name is the one you have?
   / Lawn aerator/ plugger #7
Do each of the wheels turn independently or is the axle one solid piece?
   / Lawn aerator/ plugger #8
The wheels are hooked together in groups of 2, only 1 spoon hits at a time in that group. It would be easy to change it to fully independent but I am not sure it if would be worth it.
   / Lawn aerator/ plugger #9
Thanks for the reply
   / Lawn aerator/ plugger #11
I haven't purchased one yet but from what I have seen the EA aerator 36" model should be just right for a BX. If you get one of these please post your results.
   / Lawn aerator/ plugger #12
Actually I run a 56 inch Landpride behind my BX with no problems. I do horse pastures, soccer complex, and large customer yards with no problems at all.
Thanks
Bob
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59905)
2019 WABASH...
pressure washer, and trailer (A56859)
pressure washer...
2018 HINO SA (A58214)
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
