Converting lawn tractor attachment to 3PT
   / Converting lawn tractor attachment to 3PT #1
asylum575
Rockland Cty, NY(sou. NY)
Kubota BX24
Anyone ever convert lawn tractor attachments to 3 point equipment. I have a dethacher and plug aerator for my ccraftsman lawn tractor. Anyone ever hear of attaching bars to use it with a 3point hitch. I have a BX. Worth it or not?
   / Converting lawn tractor attachment to 3PT #3
It can be done, I built a frame to hook to the 3 pt and modified a dethacher and core areator to quick attach to the frame. It works good, but you have to only go in straight lines with the core areator. I will attach some pictures.
   / Converting lawn tractor attachment to 3PT #4
Yep, I did the same as Harleyscooter (not as purty as his), but yeah.
Depends on how handy you are in the workshop I guess. You can remove the draw bar from your aerator and dethatcher and adapt a 3pt hitch to carry the implements. My Aerator was a standard Northern Tool 48" unit. Took about 1.5 hours to modify to suit the 3pt lift.
Boy does it make it a lot more managable to use the aerator on the 3pt... I wish I did it a long time ago...
Ditto on the straight lines recommendation above. You have to lift the aerator to turn. You can make gradual turns but only slight before you start to hear groaning from the implement. Wouldnt recommend trying to turn too often when it is engaged...
I'll see if I can get a couple of pics up later...
Harley,
looks like the same stuff i have. Think it's agri-fab or something like that. I figured it would work well with the BX. I'll take a closer look tomorrow.
Thanks
   / Converting lawn tractor attachment to 3PT #6
I'm looking to either build or buy a dethatcher just like this. Could you point me in the right direction as to how or where?
   / Converting lawn tractor attachment to 3PT #9
excellent...thanks! Do they sell units that attach to a bucket or the front end too? Wondering if I can dethatch, mow and bag all at once?
It looks like that particular company has a front mount, but the name having Z-Turn in it makes me think it's more designed for a zero turn mower. However, I did a Google search on "Front Mount Dethatcher" and a number of hits come up. Here is one that looks like it would bolt to the front, hard to say if existing holes would mate up or if you'd have to drill some new holes...
Front Mount Dethatcher - Tractor accessories
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
