John Deere 125 lb Electric Spreader
   / John Deere 125 lb Electric Spreader
Back again!
After explaining the wiring installation to you, it occurred to me to remove the existing switch and length of wire from the spreader since I am not using it and install the shorter wire shown in the picture draped over the seat! Now I have a very clean installation with just the right length of wire!
Neat, now I can't wait to try it out!
Just need some dry weather for a day or so.....
   / John Deere 125 lb Electric Spreader #12
It is easy to complain about JD , and at times valid .But now and then they come up with something that works .
Hi Kevin 37b,
Don't get me wrong, No complaints here, I will continue to purchase John Deere products. I was just surprised the accessory outlet at the right rear fender wasn't taken advantage of....and that maybe the aftermarket supplier's design in making the unit workable with many brands of tractors.
What do the controls look like on this spreader?
I just had my Earthway unit out on the ATV. I may consider adding a subconnector so I can power it via the rear power port on the new x750 as well. The supplied fuse in mine is 10amp FYI.
I used mine to do an overseed on pasture and hay field. Worked fantastic. I had the spreader on the rear rack and chain harrow behind to help distribute and cover the seed as it came out.
With this spreader there are 3 teardrop shaped drop holes. Two can be blocked off manually leaving only the one hole. This worked exceptionally well at rationing the seed. I ran with the single hole open at setting 4 I believe and stretched a 50# bag out over 3-4 acres of already established field.
I'll need to build a mount to use on the 750 with the 3 pt though. Might just stick with the ATV as the suspension does wonders across the rough and it's far from maxed out to travel at 6-8mph.
I like your idea of using a chain harrow to help distribute the material. I wonder if a 4'x 4' section of chainlink would work as well?
   / John Deere 125 lb Electric Spreader #15
Hi Guys,
Here are some pics of the Spreader Installed. The "Extra" wiring on the seat came with the spreader to run back to the battery with the purple wire connecting to the ignition ( that must shut the unit off with the ignition switch is positioned off)
I went to Tractor Supply today and picked up the accessory plug you see next to the Tractor's accessory outlet. Accept for the extra wire tied to the tractor fender handle I think this install is cleaner. If all works well I will cut the wire shorter and install an accessory plug directly to the spreader wiring.
Also I may go back to TSC and purchase a neat wireless controller! It was only 30 bucks.....
I'm not sure if I'm seeing this right, but is the spreader connected to the click-n-go brackets?
Yup, I needed to remove the click-n-go suitcase weight bracket and the spreader took its place. There is also a bracket at the center point that attaches down to the existing hitch bracket.
   / John Deere 125 lb Electric Spreader #17
Does any one know if I can use the John Deere electric spreader if I have a three point hitch with the lift arms removed on my X728 I just ordered the Earthway pull behind spreader but thinking of canceling it if I can use electric unit with an easy hook up
Hi rboss75
The installation instructions don't mention having to remove the lower draft arms nor do they mention having to remove the upper link arm. If you look at the pics I sent it looks like the link arm maybe the only thing in the way. You will need the click-n-go brackets to mount the spreader to the tractor. Also I purchase the barrier shield to keep the material from hitting the back of the tractor and unbeknown to me it installs behind the spreader I guess to keep material from shooting too far behind the tractor?
So tonight I went to Lowes and purchased a piece of polycarbonate and fabricated my own shield to protect the back of the tractor!
All n All I am very happy with the construction of the spreader. I will try it out this weekend and report back!
   / John Deere 125 lb Electric Spreader #19
Ok. Great thanks for the info. When you take off the spreader can you take a photo of the click & go bracket. For some reason I think that the three point set up ( not the lift arms) will not be compatible. Than you
   / John Deere 125 lb Electric Spreader #20
It is my understanding that the click and go bracket is not compatible with the three point hitch. I would be interested in an IMatch compatible model myself. Right now I am using my larger spin spreader on the IMatch with the x749 it works well but I don't overload it either.
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
TROY BUILT PRESSURE WASHER (A51248)
TROY BUILT...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
