Gear motor for drill press
   / Gear motor for drill press
More likely there is an internal centrifugal switch on the red line.
larry
Surplus Center responded today and said there was no centrifugal switch, according to their information.
   / Gear motor for drill press #32
They are a special kind of relay. Called "current sensing" relay.
They have a few (10-20) turns of heavy wire for the coil. Used instead of the internal centripetal swich. The pull in and drop out current is different but they're made with that in mind.
Thanks! Learn something new every day. I looked them up. SC should not have used the generic "relay". That type of relay is expensive.
larry
   / Gear motor for drill press #33
Well darn. Its buy an expensive relay or use one of the start options I sketched earlier if it wont start on just the run cap. :confused3:
larry
Well, here's a summary of my options:
1) use the AC gear motor: Surplus Center - 743 RPM 115 VAC INLINE GEARMOTOR but the relay info is ambiguous and the rpm I can get from it is about 200 and I would like about 100).
2) use a DC motor: Surplus Center - 350 RPM 90 VDC INLINE MINARIK GEARMOTOR but is more expensive, speed will allow me to get ~80 rpm, but then my max rpm is only ~400, too low.
3) go with a jackshaft. I would need about a 10" max step pulley to get ~100 rpm and I can't find one and I'm sure it is expensive if I ever do.
I guess I'm just hard to please. :eek:
Bob
   / Gear motor for drill press #36
The drill press shown on the roguefab website is exactly the same as the one I converted using an inverter drive and a 3 phase motor.
I think the inverter drive is a much cleaner solution and gives me a much wider speed range than the jackshaft setup, plus giving me the ability to reverse the spindle.
   / Gear motor for drill press #37
My large HF DP, the 20-inch "production" model, only goes down to 180 RPM. I
would like to get down to 80-100, ideally.
I picked up a free washing machine motor....it has 2 speeds. I have yet to try
it, however. The lower speed would work well, it would seem. Anyone try that?
That was the first motor I put on my Jet ~35 years ago. It eventually died and I replaced it with a single speed. I missed the dual speed but in my case, going from 1725 to 1140 rpm wouldn't give low enough rpm. In you case it should work fine. Do it.
BTW I have orderd shafts and pulleys to make a jack shaft. I'm giving up on high rpm. Thanks for all the input.
Bob
   / Gear motor for drill press #39
To add to the discussions, search ''DC treadmill uses'' or something like that. Many are used on lathes and drill presses.
Al
I finished the jackshaft installation. The 5/8" keyed shaft is supported by two 1/2" x 1" steel bars. I get a 4:1 speed reduction giving rpms between 135 and 750. The only problem is belt slippage when sawing a 3" dia hole in steel and occurs on the smallest pulley (1.67" dia) on the cone above the large idler. There is no chatter when drilling but the slippage limits the torque; it took about 15 minutes to saw thru the 1/4" plate shown but it saws very cleanly. I've got the belt pretty tight and am afraid to tighten it more because the shaft is only 5/8"; I probably should have used a 1" shaft. The belts are old ones I have taken off old equipment so they may not have adequate friction. Would belt dressing help?
Bob
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
John Deere skidsteer (A55788)
John Deere...
Margaritaville Wall Art (A55853)
Margaritaville...
2014 DODGE RAM 5500 HEAVY DUTY UTILITY TRUCK (A57192)
2014 DODGE RAM...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
