3 point lift jerky on Kubota M6800?
   / 3 point lift jerky on Kubota M6800? #1
Mseriesfreak
Member
I just bought a 02 M6800 2wd cab with 1900 hrs.I hooked my heavy JD609 bushog to it yesterday and when you raise it up it is pretty jerky.The rotary cutter is 6' and is very heavy.I can pull in and out on tractor PTO shaft about a 1/4"Is this normal?
   / 3 point lift jerky on Kubota M6800? #2
a jerky 3pt on an M series never heard of that as far as the pto shaft that not normal at all
   / 3 point lift jerky on Kubota M6800? #3
I think 1/4 " movement of pto shaft is OK. Have you changed hyd filter since you purchased tractor? If so how long ago?
I have not changed the filters.Does the valve under the seat have anything to do with my problem or it is just for lowering the speed of 3 point hitch?
   / 3 point lift jerky on Kubota M6800? #5
It is just for the lowering speed of the 3 point hitch.
   / 3 point lift jerky on Kubota M6800? #6
2013 Mack GU813 Roll Off Truck, VIN # 1M2AX13C1DM019680 (A51572)
2013 Mack GU813...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
CONTACT INFO (A53084)
Two Post Car Lift (A50120)
Two Post Car Lift...
Hyster H225E (A47384)
