3 point lift jerky on Kubota M6800?
   / 3 point lift jerky on Kubota M6800? #1
Mseriesfreak
Member
I just bought a 02 M6800 2wd cab with 1900 hrs.I hooked my heavy JD609 bushog to it yesterday and when you raise it up it is pretty jerky.The rotary cutter is 6' and is very heavy.I can pull in and out on tractor PTO shaft about a 1/4"Is this normal?
   / 3 point lift jerky on Kubota M6800? #2
a jerky 3pt on an M series never heard of that as far as the pto shaft that not normal at all
   / 3 point lift jerky on Kubota M6800? #3
I think 1/4 " movement of pto shaft is OK. Have you changed hyd filter since you purchased tractor? If so how long ago?
I have not changed the filters.Does the valve under the seat have anything to do with my problem or it is just for lowering the speed of 3 point hitch?
   / 3 point lift jerky on Kubota M6800? #5
It is just for the lowering speed of the 3 point hitch.
   / 3 point lift jerky on Kubota M6800? #6
16FT Flatbed Trailer (A51573)
16FT Flatbed...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2016 Ford F550 Flat Bed (A52377)
2016 Ford F550...
