How many hours on your Mahindra?
   / How many hours on your Mahindra? #21
I have almost 70hrs on my 4025. I've had it since August of last year. No major problems so far.
   / How many hours on your Mahindra? #22
43.5 on mine, as of yesterday.
biggest problems to date:
-thorn in a front tire the day I got it (talk about a buzz kill. slime and a tire patch, and victory)
-seat switch wiring got damaged from spinning the seat around for the backhoe.
-not sure on the rear diff lock yet.
nothing really big, the seat thing was a pain only because the dealer had to come out with a new seat, and even then it didn't result in any downtime for me (guy came out while I was at work, and the tractor was ready to go waiting for me when I got home), the diff lock situation is a bit of an enigma, though. I think it has a mind of it's own and most of the time that mind is somewhere else. Fortunately I haven't really had a need for it, so I'll bring it up if/when the tractor goes in for service.
   / How many hours on your Mahindra? #23
10 hours :laughing:
1. I'm not an owner of a fleet of tractors, but I conduct in-depth studies of the enterprise architectures of several industries (food, tech, service and manufacturing). I believe there can be any number of business or financial-related reasons for replacing equipment ahead of it's time (depreciation and amortization schedules and other SEC realities)
2. The new emission regulations compelled a lot of manufacturers to stock-pile major end-items before the end of 2012.
3. I think a comparison between the track records of owner operators and fleet owners (without dedicated-professional maintenance crews) would reveal that owner operators perform better maintenance; get more life out of their equipment.
   / How many hours on your Mahindra? #24
10 hours :laughing:
Oops, a solar flare caused a double post
   / How many hours on your Mahindra? #25
485 and only about 2 on the BH!! too wet for digging!
   / How many hours on your Mahindra? #26
26.3 on my 5035HST
Rear work light has never worked since day one. Brake lights stopped working for a while and suddenly started working again (shrugs). Haven't even bothered to see if work light is just bulb or what, not too worried about it right now.
No major issues anywhere. HST does take some time to get used to, but now that I am, love it.
   / How many hours on your Mahindra? #27
Question for you, I am about to attach my canopy on my 2810, I bought my tractor used and the canopy was sitting off in a barn with no hardware. I bought some square bolts for it, but I noticed on your pic you have a couple angled bars for bracing towards the front. Your modification or is that OEM?
   / How many hours on your Mahindra? #28
There are 2 square tubes U-bolted to the ROP that the canopy bolts to. The braces bolt to the tubes and are U-bolted to the upright as seen in the pic for support. Bolting directly to the ROP without a front post might not work. Also not recommended to drill or weld a ROP. My canopy is a fiberglass after market and came with all the hardware. The only welds are small angles on the braces to hold the u-bolts in place
   / How many hours on your Mahindra? #29
47 hours on my 2516,anyone know how much $ it will cost at the 50 hour mark?
   / How many hours on your Mahindra? #30
I'm taking the advice to perform the 100 hour service at my (3016's) 50 hour mark; too much metal in the break-in oil for my likings. I plan to give my dealer the business for oil & filters (so far 2 fuel filters with o rings, and 2 engine oil filters cost 25 bucks), and perform the work myself.
Walking through the part stores, it looks like the hydro fluid will be the most expensive.
   / How many hours on your Mahindra? #31
That actually sounds like a darn good idea! It certainly can't hurt!
Thanks
   / How many hours on your Mahindra? #32
73, just set 29 poles for a barn with my 5530! Best tractor I have ever owned.
   / How many hours on your Mahindra? #33
Not completely the correct thread, but I went off topic in it and wanted to close it my "question". I ended up mounting my canopy last month and now have 3 mows and 6+ hours of use with it mounted in this fashion. I simply went to tractor supply and bought 2 sets of square frame trailer axle/leaf spring bolts packs for about $8 per pair. Fit perfect and does a great job for my 2810, mounted solid as a rock, no flex at all. And to keep the thread on track, 891 hours as of 6/16/13....
   / How many hours on your Mahindra? #34
Just bought a 1997 485 with 1930 hours on it. It leaks a little oil and hydraulic fluid but not to bad. Runs great and starts fine good little tractor.
   / How many hours on your Mahindra? #37
Recently traded my 2516 for a 4025 and it just turned over to 10 hours. Clearing out another half acre of woods for our 3rd food plot.
   / How many hours on your Mahindra? #38
I like this tractor a lot!
Pictures.
   / How many hours on your Mahindra? #39
Slickhead - why the chains on the rears?
   / How many hours on your Mahindra? #40
I keep them on year round,they add a lot of traction in the woods. Plus I fitted them so tight there a pain to put on.
2019 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2019 CATERPILLAR...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
TANK MANIFOLD (A55745)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
