davehowell
Member
Since I have both clamp on pallet forks and a Ratchet Rake for a B 7800 with loader and backhoe let me chime in.
The pallet forks, in my case, three on the bucket, just held with the clamps are great for hauling brush. Lots of volume but little weight. They also pick up my calf sheds when I want to move them. If you try and pick up anything with any weight on a pallet, I am scared that you would bend the bucket lip. But for moving big, awkward objects, they are great.
I do pick up 4 by 5 round bails, sideways, not using them as a bale spear, and that seems to work well. I tip the bucket so that that weight is off the tines. The weight of the bale is maybe 1000 pounds, max. Drive carefully, especially if off a hard surface.
One could use the slots and chain binders to put the load on the back of the bucket instead of the loader lip. I will probably end with doing this.
The Ratchet Rake works well, as a easy/easy off bucket addition. I can't ever imagine digging with it. When the ground is torn up by the backhoe, the Ratchet Rake goes on in seconds and does a good job of preparing the disturbed area for reseeding. We haven't used it for vegetation tear outs, or grading lanes. Using the loader float, we use it for leveling and preparing an area for reseeding, usually with the larger teeth. The small teeth are then used to make a good seedbed and the pulling the small teeth backwards seems to cover up the scattered seed very well . For our use,it works well.
HOpefully useful
HOpefully useful
