Midniteoyl
Elite Member
- Joined
- May 20, 2013
- Messages
- 4,773
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Hey guys.. I have a Ford 3400 with a 730 loader. When I first got it, the lift and bucket cylinders leaked down fast due to multiple external leaks (lines, cylinder caps, etc). I have tightened/fix all those and now the bucket holds unloaded, and drops slowly loaded, and the lift arms still drop, but slower than before. Ok, still a leak somewhere, possibly in the cylinders, right? Well, while playing around, I found that the bucket tilt control will actually raise the lift arms. Tilt the bucket back and the lift arms slightly raise until the bucket is full back against the stops and then the arms go up fairly quickly. Even hits the pump hard enough to activate the governor and idle up the engine.
So, question is, is the indicative of a leaky cylinder (bypassing?) or maybe a bad controls in need of rebuild? Both?
Thanks guys..
Thanks guys..
