Bucket tilt lever controls lift arms? Ford 3400 / 730
   / Bucket tilt lever controls lift arms? Ford 3400 / 730 #11
Jim:
The centering spring and detent system should be under a cup shaped cover on the end of the valve body opposite the end of the spool that connects to the actuating lever.
Best to remove the valve and work on a table (in the kitchen in your wife permits). The spring/detent system often shoots out little parts when you take the cover off. Remove the spools (mark which one goes where), clean the valve body, and check out the centering springs. One may be broken or just weak.
Thanks again Farmerford.. As soon as I can, I will take it apart. Unfortunately, it will not be on the kitchen table :)
Well.. I didnt take the valve apart yet.. but... After using it a few hours and a neighbor moving peat moss and top soil for 5+, the bucket tilt no longer makes the arm raise when at full back tilt and the arms fall very, very slowly now.. So, I'm thinking simply dirty/sticky valves that are now clearing up. Cool :thumbsup:
Question: if I was to change the fluid and filter, would regular UTF work?
   / Bucket tilt lever controls lift arms? Ford 3400 / 730 #14
No, not if the pump was designed to work with motor oil.
   / Bucket tilt lever controls lift arms? Ford 3400 / 730 #15
Have you did a pressure check.
Have you cleaned all hyd filters?
You could have multiple troubles, such as worn pump, worn valve , bad piston seals in the cyl, etc.
Type of fluid is least of your worries.
Just about any mineral based fluid will work.
Electric Concrete Mixer - (A51573)
Electric Concrete...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53472)
Gooseneck...
JOHN DEERE 7210R LOT NUMBER 269 (A53084)
JOHN DEERE 7210R...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
