How much liquid can 20x10x8 tubeless tires hold?
   / How much liquid can 20x10x8 tubeless tires hold? #1
shearer500
Bridgeport
John Deere LT155
I am going to use windshield washer fluid.
   / How much liquid can 20x10x8 tubeless tires hold? #3
Not enough to be worth the bother IMHO. I can't find a ballast chart with that small of a tire. If one holds 3.5 gallons I'd be mildly surprised.
   / How much liquid can 20x10x8 tubeless tires hold? #4
My Deere X300 has those tires and I filled them with WW fluid a couple years ago. Took 5 gallons each - 10 gallons total. I used a old punp up sprayer which I cut the wand off. the hose fit onto the valve stem perfect. Pulled the valve out - put valve stem at 12 o'Clock position. Had to pull the hose off every so often to let air out. Took about an hour total. Really helps on the hills I have and when plowing snow. I posted it on "GardenWeb" "loading garden tractor tires for weight"
   / How much liquid can 20x10x8 tubeless tires hold? #5
filled all four of the tires on Dads Huskie 3 years ago, we filled them with 14 to 16 gallons also, what a difference it made. the traction on slick wet grass is great and the extra weight really helped the ride on rough ground.. since then i have filled 3 more sets for people
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2019 Kaufman Pro Series Car Hauler Trailer, VIN # 5VGFE4736KL004723 (A57453)
2019 Kaufman Pro...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
Toro Utility Cart (A59228)
Toro Utility Cart...
