Food Saver Vacuum Pack
   / Food Saver Vacuum Pack #51
Normal air pressure is about 15 psi. As you remove the air the force it puts on the meet is reduced and the pours of the meet open up to allow the liquid to enter much easier than normal. That's why you need to use a rigid container, not the plastic bags to marinate.
   / Food Saver Vacuum Pack #53
Anyone try one of this? Seems like it'd bee good while camping/fishing/hunting/hiking/etc..
Pump and Seal food saver vacuum sealer is better than Tilia FoodSaver
Did you watch the video demonstration? I think I'd much rather have the Ziplock Vacuum bags and their simple little pump, which is what we have and have been using before buying the FoodSaver. Maybe I'm wrong, but that Pump and Seal thing just looks like it would be too much trouble and take too long to be of any value.
   / Food Saver Vacuum Pack #54
Feel free to ignore this...it is only food for thought.
Vacuum's tricky. If we watch some of the educational shows like "How do they do it?" and "Factory made" etc, we can see that they use vacuum to make components conform to a mold. The atm pressure is making it conform, and the pressure is being exerted across the plastic.
My theory: the plastic mashed the meat, and some air comes out, but mostly liquids get displaced, only to be replaced with different fluids each time the meat re-expands.
Like many of you, I milked cows for years, and vacuum got to be one of my best pals. (Since I cannot possibly milk a modern cow by hand.) The milk is expressed by a differential pressure across the teat...the udder being under atmospheric pressure (plus ejection pressure, which wanes,) but the milkers themselves are under vacuum. Pulsators keep the blood from pooling by releasing the vacuum, producing a massaging action in the liner. I think the meat is likewise being massaged during the marinade.
The problem with your theory is that the vacuum sealer I use has a special marinade container not a plastic bag. :):):) You fill the marinade container with meat and marinade, put on the lid which is air tight and connect the contraption to a hose from the vacuum sealer. No bag is used. There is a button on the sealer that pulses the vacuum on and off. Gracious this is making me hungry for some MEAT! :laughing::laughing::laughing: Danged nuts I had for lunch ain't a good substitute for jerky! :D:D:D
Maybe I am hankering for meat because of the lack of same at dinner last night. The wifey bought some Banana and Jalapano peppers for dinner. I cut them in half, cleaned out the seeds and pith and stuff them with flavored cream cheese. We have done this in the past for peppers grown in our garden and really liked it. I found a dohicky to do this on the grill but it did not really work with the large peppers we bought so I cut the peppers in half. I did cook them on the grill though and they were pretty good....
Except for the EXTREME SPICY HEAT of those peppers! They were so hot, even the banana peppers were hot. The peppers were too danged hot to eat! We threw most of them away. I can't believe how hot those peppers were especially the banana peppers. I did grill some mushrooms that were really good....
I wonder if I could have marinaded the mushrooms? DUH! Wish I had thought about that last night... :rolleyes::laughing::laughing::laughing:
Later,
Dan
   / Food Saver Vacuum Pack #55
Was thinking more about keeping coffee fresh in a jar :)
But, it works without power was the main thought.. Gut fish and place in bag before throwing it into a cooler..
   / Food Saver Vacuum Pack #57
Later,
Dan
Shucks!
Thinking further about it, I think in that case the cell walls and membranes in the meat will be the new bags. Just imagine how they must be responding. I doubt the process is altering osmosis, so this seems like about all that is left. Can anyone think of anything else?
Egon mentioned positive pressure being better. Once they release the vacuum, to the meat it looks like pressure of equal magnitude to the vacuum that was applied. It's a safe and cheap way to apply a pressure differential.
   / Food Saver Vacuum Pack #58
   / Food Saver Vacuum Pack #59
Anyone know what level of vacuum ought to be applied?
   / Food Saver Vacuum Pack #60
That Handcrank Pump would work just fine and he's using the FoodSaver attachment. I guess using that pump would be good exercise, although some of us might not have the strength to pump it long enough.:laughing:
Bird, you need to invent one that uses a bicycle, pedal vacuum:laughing:
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
