Are stainess and carbon steel "dissimilar metals" re: electrolysis?
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My small street rod has a steering shaft with a stainless steel u-joint. As a safety system the u-joint has threaded holes to use set screws to lock the steering shaft in place. Trouble is, I can't find stainless set screws and there is not enough room to use a stainless bolt. Note here--I add a lock nut to hold the set screws in place.
I would prefer not to use anti-seize Because of the potential to get it on my interior.
So, will carbon steel react with stainless steel? Will anti seize stop the problem? Any other ideas?
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #2
Nice you are at least concerned about the reaction of dissimilar metals that are in contact. Since you've not mentioned the series of SST you're talking about, can't say for sure what if any problems you might see.
Not sure what you mean by anti-seize. It is not uncommon to use a thread locker like Loc-Tite to help with preventing corrosion in threads. I'd use either 222 or 242 for this. The 242 is a little stronger in its "holding" ability so I'd use that if you are concerned about the set screw backing out.
I have both 222 and 242. Would that form a barrier to protect against a problem? Only one set screw sort-of concerns me because there is not enough space for a lock nut. What about coating it with women's clear nail polish? I've done that with other things.
Anti-seize is just the normal silver colored paste to use when assembling dissimilar metals.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #4
Marine retail centers often have SS set screws to be used with boat railings etc, tho' those are usually just 1/4"x20s of different lengths. Most any tooling supply house (Grainger, McMaster-Carr, Fastenal) will have other sizes & they're easy to find online. Boaters will be familiar with how bare SS nuts/bolts will gall or seize on themselves, esp when power driven & allowed to heat up by friction (BTDT), but I'd use them for anything exposed to weather or road conditions.
SS alloys aren't entirely non-corrosive in all uses, tho' determined by proportions of nickel & Chromium they are stain resistant to varying degrees. +1 on using Locktite with SS. You'd see why when tightening or disassembling anything SS & you aren't breaking stuff as you go.
btw: In my shop, I don't like stainless one bit. It's hard on tooling and is difficult to get a good finish on without a bit of fuss. But, when fabricating or on the motorbikes I reach for off the shelf SS nuts & bolts whenever I can find 'em, & 242 is my 'go-to'.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #5
Stainless and aluminum are bad in salt water (boat engines) so they put a chunk of aluminum on the lower unit called a sacrifical anode that will eat away ove time. Galvanic corrosion or something like that...
Even stainles bolts and stainless nuts can "gall" and not come apart, so some antisize it not a bad idea on them in some cases.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #6
zinc anode
OK, I'm going with the Loctite on the threads. The thread size is maybe 3/16" and is a set screw.
Should I use 222 or 242?
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #8
There won't be any galvanic action between dissimilar metals unless there is an electrolyte. So it doesn't matter what you use.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #9
There won't be any galvanic action between dissimilar metals unless there is an electrolyte. So ...
So .. I'd avoid puddles, leave the street at rod home on days that might rain, and keep a dehumidifier in the garage. My reloading bench and shop machines are in the same room downstairs. Without a dehumidifier there, carbon steels (firearms, machine tables/chucks/vises/parallels/angle plates/some precision measuring tools) will rust without contacting anything else. (I don't suppose it's ever humid in Ohio .. :))
One thing not yet mentioned is to fill set screw holes with silicone sealer, but not easy if they're sticking out with a locking nut on them unless you cover both completely. SS nuts/bolts/screws don't cost all that much, but you could save some $$ ...
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #10
OP states he doesn't want to use anti sieze because it might get on the interior of the car, which indicates u-joint is on the inside of the car. No need to avoid puddles or rain if that's true.
Rust and galvanic corrosion are different things, OP didn't ask about rust.
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
JOHN DEERE 8295R LOT IDENTIFIER 151 (A53084)
JOHN DEERE 8295R...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
JOHN DEERE 48" REAR BAGGER (A51248)
JOHN DEERE 48"...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
