Bucket tilt lever controls lift arms? Ford 3400 / 730
   / Bucket tilt lever controls lift arms? Ford 3400 / 730 #11
Jim:
The centering spring and detent system should be under a cup shaped cover on the end of the valve body opposite the end of the spool that connects to the actuating lever.
Best to remove the valve and work on a table (in the kitchen in your wife permits). The spring/detent system often shoots out little parts when you take the cover off. Remove the spools (mark which one goes where), clean the valve body, and check out the centering springs. One may be broken or just weak.
Thanks again Farmerford.. As soon as I can, I will take it apart. Unfortunately, it will not be on the kitchen table :)
Well.. I didnt take the valve apart yet.. but... After using it a few hours and a neighbor moving peat moss and top soil for 5+, the bucket tilt no longer makes the arm raise when at full back tilt and the arms fall very, very slowly now.. So, I'm thinking simply dirty/sticky valves that are now clearing up. Cool :thumbsup:
Question: if I was to change the fluid and filter, would regular UTF work?
   / Bucket tilt lever controls lift arms? Ford 3400 / 730 #14
No, not if the pump was designed to work with motor oil.
   / Bucket tilt lever controls lift arms? Ford 3400 / 730 #15
Have you did a pressure check.
Have you cleaned all hyd filters?
You could have multiple troubles, such as worn pump, worn valve , bad piston seals in the cyl, etc.
Type of fluid is least of your worries.
Just about any mineral based fluid will work.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2018 CASE IH 110N LOT IDENTIFIER 208 (A53084)
2018 CASE IH 110N...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
