127 gyramor rotary cutter by john deere need blades
   / 127 gyramor rotary cutter by john deere need blades #1
food plot
grandisland new york
naa ford
was wondering if anyone can help me out there.?i need 11x3x3/8 bladws for my rotary cutter.i went to john deere dealer and wow they shocked me!told me i can only order blades with individual side packages that include the blades and hardware for 102.00 per side.i dont need 120.00 in extra nuts and bolts that i already have.i just need 11x3x3/8 thick flat blades.any info would be great where i can buy just the blades..thank-you
   / 127 gyramor rotary cutter by john deere need blades #2
Did you happen to get the part number for them? If not get, and I may be able to help you out.
   / 127 gyramor rotary cutter by john deere need blades #3
AGY 43W or AGY44W or AGY45W are no longer available from JD. I'm guessing the dealer was subbing the 1/2" thick blades and longer bolts. One must realize that that cutter ceased being built in the late 50's.
The part numbers are
AGY 43W series # 003 Blade flat 3/8" thick (pkg of 2)
AGY 44W series # 003 Blade, suction, 3/8" thick (pkg. of 2 )
I prefer the flat blades.
Any help is appreciated.
Tx Jim If they no longer make these blades , can I get after market blades for it? or do i have to scrap the machine that is in very good condition. any help is appreciated
   / 127 gyramor rotary cutter by john deere need blades #6
Those are deff not John Deere part numbers, the dealer may have quoted you an aftermarket blade price.
   / 127 gyramor rotary cutter by john deere need blades #7
The part numbers are JD PN's. Inspect parts keys #2,3 & 4
   / 127 gyramor rotary cutter by john deere need blades #8
If I were you I'd check at Shoups or Farm & Ranch type stores.
   / 127 gyramor rotary cutter by john deere need blades #9
Just how old is this cutter? NEVER seen any John Deere part numbers like that before.
   / 127 gyramor rotary cutter by john deere need blades #10
2002 STERLING LT9500 DAY CAB (A51222)
2002 STERLING...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
