127 gyramor rotary cutter by john deere need blades
   / 127 gyramor rotary cutter by john deere need blades #1
food plot
grandisland new york
naa ford
was wondering if anyone can help me out there.?i need 11x3x3/8 bladws for my rotary cutter.i went to john deere dealer and wow they shocked me!told me i can only order blades with individual side packages that include the blades and hardware for 102.00 per side.i dont need 120.00 in extra nuts and bolts that i already have.i just need 11x3x3/8 thick flat blades.any info would be great where i can buy just the blades..thank-you
   / 127 gyramor rotary cutter by john deere need blades #2
Did you happen to get the part number for them? If not get, and I may be able to help you out.
   / 127 gyramor rotary cutter by john deere need blades #3
AGY 43W or AGY44W or AGY45W are no longer available from JD. I'm guessing the dealer was subbing the 1/2" thick blades and longer bolts. One must realize that that cutter ceased being built in the late 50's.
The part numbers are
AGY 43W series # 003 Blade flat 3/8" thick (pkg of 2)
AGY 44W series # 003 Blade, suction, 3/8" thick (pkg. of 2 )
I prefer the flat blades.
Any help is appreciated.
Tx Jim If they no longer make these blades , can I get after market blades for it? or do i have to scrap the machine that is in very good condition. any help is appreciated
   / 127 gyramor rotary cutter by john deere need blades #6
Those are deff not John Deere part numbers, the dealer may have quoted you an aftermarket blade price.
   / 127 gyramor rotary cutter by john deere need blades #7
The part numbers are JD PN's. Inspect parts keys #2,3 & 4
   / 127 gyramor rotary cutter by john deere need blades #8
If I were you I'd check at Shoups or Farm & Ranch type stores.
   / 127 gyramor rotary cutter by john deere need blades #9
Just how old is this cutter? NEVER seen any John Deere part numbers like that before.
   / 127 gyramor rotary cutter by john deere need blades #10
71067 (A49346)
71067 (A49346)
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
