Steel vs wood deck for trailer
   / Steel vs wood deck for trailer #1
KenB2920
Almont, Mi
Kubota L5240HSTC
Looking at trailers approx 12,000 GVWR dovetail equipment trailers. Pros and cons for both steel and wood decks
   / Steel vs wood deck for trailer #2
Steel gets slippery when wet and also allows steel tracked equipment to slide around easier.
   / Steel vs wood deck for trailer #3
Wood is easier to replace when the time comes.
   / Steel vs wood deck for trailer #4
Steel gets very slippery. I also don't know that steel withstands abuse any better, and its nice to be able to replace a single board if needed. Plus of steel, no loose boards.
   / Steel vs wood deck for trailer #5
I have used both, and both are slippery when wet. Nothing works well on wet surfaces, but when wet, rubber tracks do better than steel.
I have never seen a factory built equipment trailer with a full steel deck, for the reasons already cited and weight being another,
and I for one would not want a steel decked trailer for equipment hauling.
   / Steel vs wood deck for trailer #6
PROS:
You can nail into boards.
Boards won't put scratches or dents in your equipment.
Boards easy to replace.
Boards can be replaced one at a time rather than entire bed.
Boards don't rust.
Steel doesn't decay.
Steel can be welded.
   / Steel vs wood deck for trailer #7
I've seen many steel bed equipment trailers with a pair of 2x boards bolted in each tread area.
Bruce
Thank you all for the fast replies. It looks like I will be going with wood. It seems more user friendly.
Not my next question. Is a deluxe model worth $300. For this you get "drumroll".: LED lifetime lights in conduit, locking metal toolbox and radial tires.
   / Steel vs wood deck for trailer #9
Anything that makes lights more reliable is a plus to me, then add radial tires. I say the deluxe model is worth the price.
   / Steel vs wood deck for trailer #10
I agree ^^^ LED lights last a longgg time
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Pallet Fees (A50775)
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
