Are stainess and carbon steel "dissimilar metals" re: electrolysis?
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #11
There won't be any galvanic action between dissimilar metals unless there is an electrolyte. So it doesn't matter what you use.
Good point..
I would consider just giving it a shot of a something like this Black Liquid Spray Tape if salt or fertilizer etc may get to it...
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #12
Rust and galvanic corrosion are different things, OP didn't ask about rust.
Mis-communication there, or do I deserve a spanking? OP did ask about 'electrolysis' (galvanic corrosion) and though there would be little/none to fear we did go a bit beyond that somewhere between the title & my un-welcomed four letter word.
My own concern was about environmental effects in general on carbon steel. If we avoid the r-word it can still 'corrode' in high humidity. That's all I was getting at. :) (CS will work fine, but should SS screws be avoided?)
I'm sure the OP can see between our apples & oranges. What we might be discussing is whether using Loc-Tite with either screw material means he wouldn't need/want a lock-nut.
btw: I agree a 'liquid tape' could seal it all up. It comes in colors & brush-in-can as well as the spray, but I wouldn't use it without Loc-Tite, and might not want it in a tiny set screw hole under the dashboard (1/8" for a 3/16" set screw?) if it would ever be disassembled. (I didn't hear welding as an option. ;))
http://www.plastidip.com/home_solutions/Liquid_Tape
http://www.homedepot.com/p/Gardner-...lectrical-Tape-LTB-400/100119178#.UahFW9jiERI
I'm the OP and my need comes from the fact that I had to disassemble my steering shaft after three years of carbon steel set screws into a stainless u joint (inside the cabin) and they wouldn't come apart. They were all gunked with dissimilar reaction "gunk". The set screw broke off and I tried to drill upside down and backwards. Broke the drill off and went downhill from there. Don't want to do that again.
Car only sees perfect days outside and will never even be wet. My best choice now seems to be using Loctite 222 or 242 and that will become a thread sealer. I'm a little afraid of 242 since I might not be able to get it apart if need be. Over the years I have often used women's clear nail polish as a sealer and it worked fine to keep small screws from vibrating loose. What should I use---- 222 or 242 or even nail polish?
All the comments are appreciated and very helpful.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #14
I'd go with the 242,its fine for the size fasteners you mentioned. The 222 is for small fasteners like #10 or smaller. What you don't want to use is 271, you will not get the fastener out if you use this formula. I've seen fasteners in the 3/8" range that simply twist a bolt in to when secured with 271.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #15
That's helpful, it makes it clear there is galvanic action going on. Sailors I know claim that some of the teflon based products are better for anti corrosion than antisieze, and are much less messy than antisieze. Lanocote seems to be popular. They don't use loctite for those applications but I don't know why.
Note that SS and carbon steel are very close galvanically, so while they are active, it's not like mixing some of the really noble materials with carbon steel. Another point is that once carbon steel becomes active by corroding, it is more galvanically coupled to passive carbon steel than non-corroded carbon steel is to SS. So for example, if your set screw and U-joint were carbon steel, and the U-Joint began to corrode because it's spinning and gets more exposure to road grit, that corroded material would be more reactive with the non-corroded set screw than it would if it were SS.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #16
BeezFun, thanks for the clarification!
Whether even storage or seasonal humidity is the 'culprit in the cockpit', getting seized set-screws out of SS won't be easy and risks trashing/replacing the u-joint. ($100-$200) :mur:
How can we tackle the task as a team??
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #17
Loctite data sheet indicates 242 is designed for less active materials like stainless steel, that seems like the right choice. No such claim is made for 222.
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #18
I have both 222 and 242. Would that form a barrier to protect against a problem? Only one set screw sort-of concerns me because there is not enough space for a lock nut. What about coating it with women's clear nail polish? I've done that with other things.
Anti-seize is just the normal silver colored paste to use when assembling dissimilar metals.
~3/16 sounds like it would be a 10-24 or a 10-32. Probably a 10-32.
I would use the 222. Also, although I like to use SS h'ware for a lot of things, I might consider the alloy steel in this case to help avoid stripping out the hex when you need to remove it. A small dab of chassis grease on the exposed part and inside the hex after installation will keep it from rusting. Or I guess you could coat the exposed part w nail polish.
I agree with the don't use anti-seize in this application.
If you don't want to mar the shaft, order the conformable tip set-screws:
McMaster-Carr
I did go with the 222 and figure I'm good with that. Thanks for the McMaster Carr. Who knew there were that many varieties of set screws?
McMaster-Carr
   / Are stainess and carbon steel "dissimilar metals" re: electrolysis? #20
Is this a keyed saft , square , hex . The corrosion wont happen till mother moisture shows up . Rotate it up , put a drop of SG on it and be done . You girls worry to much .
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
