Good Day everyone.
And good news, the customers unit is fixed and he will be able to finish the dog run.
I am the Service Manager at the dealership working on the customers tractor. I found a few problems with the unit after working on it myself yesterday and today.
First there was something in the backhoe control valve causing an issue with the spool for the bucket circuit. When taking the valve apart, The spool was had to move up and down w/the centering spring removed. When dis-assembled, I found no damage, or could I find what ever was causing the hang up. I took the rest of the valve apart, thoroughly cleaned and flushed it. Resealed and put back together, and on the bench all spools seemed to operate correctly.
Second issue arose after reinstalling the valve on the unit. At that point the bucket dump side of the spool would not return to center on its own. Upon inspection, I found the the bolt on the top of the control rod between then handle and spool to be to tight.
Next the seat latching issue,,, The issue was with ease of getting it latched in the normal position. Upon looking it over, I found the pins that the latch hooks on to be out of adjustment. After adjusting or straightening them, it works fine and just like the others in the yard. How they got bent, I do not have a clue. These units arrive assembled, and I see no indication of something landing on or hitting the unit. I can only speculate it happened in transit.
